I just got this driveshaft back from being rebuilt and when I installed it today I noticed there is a little play in the front. It is a double cardan and the rear is as snug as can be. On the front, there is no play whatsoever in the U-Joint where it is attached to the shaft, but where it is held in with the straps there is a very small amount of side to side play of the joint moving in the caps. I haven't noticed this before and I assume it's not good. The straps are tight and it appears to be sitting in the yoke nicely... Any ideas on why I have this side to side play in the caps?
Here are a couple pics to show where I am having the play. Notice the small gap between the cap and the joint.
Small gap when pushed ^^^^^
No small gap when pulled ^^^^^
