Product Information
Pioneer TS-A1671R 6.5" 3-Way Speaker with 220 Watts Max Power.
Specifications
Watts MAX. Music Power 220 Watts
Watts Nominal Power Handling 35 Watts
Frequency Response 30Hz ~ 33kHz
Sensitivity (1W/1m) 90dB
Ohm Rating 4
Mounting Depth 1-3/4" (44mm)
Cut-out Dimensions 5" (128mm)
Features
Woofer Cone Material Composite IMPP Cone with Interlaced Aramid Fiber
Surround Butyl Rubber for Smoother Response
Voice Coil Bobbin Glass-Imide
Voice Coil Wire Heat-Resistant Polyester-Imide Resin Coated
Damper Conex
Mid-Range 1-5/8" Laminated Polyester Fiber Balanced Dome with Neodymium Magnet and Magnetic Fluid
Tweeter 3/8" Dome
Basket Design Shallow Basket for Wider Installation Coverage
Speaker Grille New REV Spoke Grille
Custom-Fit Basket GM-Fit Basket for Improved Fit on GM Oversized 6-1/2" Applications
Price | $120 |
Rating | 3 |
Average Price | $66.95 |
Manufacturer | Pioneer |
Recommended | Yes: 21 / No: 0 |
Specifications
Ohm Rating 4
Features
Damper Conex
Tweeter 3/8" Dome
