This article discribes how to replace the Peugeot BA10/5 five speed transmission with the NV3550 five speed in a 1988 Jeep YJ.
Legal disclamer:
These are not instructions!
Always work safely and under supervision.
Do not attempt the following at all unless you are qualified!
I do not accept any responsibility for your actions based on this article.
By reading further you release me and this site from any responsibility and further indemnify me from any financial remuneration, legal procedings or otherwise.
Best Viewed In 1600x1200 mode.
Vehicle Background:
What we have here is an 88 YJ (see sig below). I DESTROYED reverse gear without too much effort and in short order (1st is complaining too). I had budgeted replacing the tranny from the moment I purchased my heap.
Rebuild Options/Goals:
My goal with this swap is simple...Get back on the road with a NEW transmission (not rebuilt or yard sourced) that will handle most anything I dish out, and not open a huge can of worms. So I did a mess of research on the NV3550 and NV4500.
Turns out th NV3550 fit the bill...here's how.
Rebuild Obsticals:
I faced some of the following problems.
Budget:
We all know the prices so I wont bore you with that. Lets just say I cant afford to do this twice.
Ease of swap:
The AX-15 would probably have been just as easy to swap as the 3550 and I'm sure many people are very happy with the 15. I might have gone AX-15 but the ratios/torque capacity is better in the 3550. The 4500 is huge and awesome...but there's a bunch more fab work and drive shaft stuff that needs doing for that swap. Rebuild the 10/5? HA HA HAA!! It would be the easiest solution for sure...But I'm gonna use it as a garden planter, or for target practice...I haven't decided yet.
Actual Durability:
Considering my torque requirements (current and future) I have decided that I will never ever go above 300 lb/ft from the engine. Given that I will be using this jeep as a driver and mild crawler/tow vehicle, I won't be needing a "trail rated" granny low, or huge torque capacity. The NV3550 is rated 300 lb/ft (conservatively) based on a GVW of 7200 lb.
I think my jeep is about half that weight.
Future Torque Capacity:
If I am correct in assuming my injected 4.2 is producing about 207 ft/lbs at the crank (180x1.15), then it's safe to say I'm in the clear with the current motor. However, assuming the conservative rating of the 3550, if I do swap in a nice new 4.0 and stroke it with the old 4.2 internals, or go with a 3.8 S/C (who knows), I will still be safe.
Timeframe:
I want a "drop-in" tranny upgrade!! Unfortunately those don't come easy. The idea of fabricating for weeks and trouble shooting after that, puts most "granny low" transmissions out of the picture for me. Time is not a huge factor for me, but I don't want to be on my back battling with mechanical jigsaw puzzles for months. The best solution is coming into focus...
Let the sparks fly!
So I ordered the NV3550 conversion kit available from High-Impact Transmission & Gear
Stage one - Teardown:
2 huge boxes arrived at my door after waiting patiently for my Sept. X-mas. The Tranny in one and the adapters/clutch in the other.
I took a quick inventory of all the stuff..."yup all there....woah....whats THAT?"....A chipped Clutch plate thats what.<Replaced Free of charge by Advance Adapters after some E-mailing and picture taking. (AA is a great company)
Parts...check.
Tools...check.
Started by removing the shifters.
Then the front and rear drive shafts came off.
The rear U-joints were in a bad state. One litterally fell apart right away, displaying the roller berings inside. The other was siezed.
Next I lowered the belly pan.
This is about the point when I broke out the ziplocks for labling and storage of "loose items".
Then I removed all the vac lines, speedo cable, backup light wires, vent tubes, and cobwebs and removed the x-fer case.
Legal disclamer:
Vehicle Background:
Rebuild Obsticals:
- Budget
- Ease of swap
- Actual durability
- Future torque handling capacity
- Timeframe
Budget:
Ease of swap:
Actual Durability:
Timeframe:
Let the sparks fly!
Parts...check.
Tools...check.
