Hello I recently purchased a 1985 Jeep CJ7 that had been modified with a 304 AMC motor - Question is there is a hose hooked to a vac port on the back of the motorcraft 2150 carb that was connected to a port at the back of the manifold. The hose had a pcv valve midtream. The engine ran rough and would not idle on a cold start. I removed the hose from the carb and plugged the vac line on the carb and the engine smoothed out. This setup is unfamiliar to me as I am used to the hose and pcv valve being connected to the breather on the valve cover. Has anyone seen or heard of this setup and is it correct?
Related experienced comments and suggestions are appreciated
Gary
Gary
