1 - 10 of 10 Posts
so the pass window auto up feature only works with pass window door switch not driver door switch. the auto down feature works with both. makes no sense.
Same thing literally just happened to me this last month where the auto up feature on the driver's side stopped working. I haven't had time to look into it yet, but I assume the tracks need some lubrication or the motor is getting worn and drawing more current than it should and trips the safety stop feature of the auto up system.
/subscribed anyway in case it is something else puerile have seen
I am probably just gonna go to a pull your own part yard around me and hit up a few jeeps. Just hope I grab the right one since there are 2 different options... TBH its not big deal really being its just the passenger window auto up doesnt work.
Mine was doing that also. I took The switch that wasn't working apart and was able to fix it. There's a little metal tab that creates a circuit and it just needs to be bent back down. It's like a little spring type connection.
Have you tried resetting the switch? The auto feature has stopped working a couple of times since I've owned my Jeep and a quick reset makes it work again. I don't remember the procedure but it's something like make your windows go up and then down while holding the button.
Take the drivers switch unit out and give it a good cleaning with electrical parts cleaner. Usually works wonders, fixed mine and other window switches. drivers in particular, sees the most dirt, moisture , crud etc. from use.
It's pretty easy to take apart. This picture is from a different vehicle, but it's pretty similar to what was in my driver side switch. I cleaned the contact points and bent the tabs a bit more so the points pushed harder against each other. It worked for my switch, maybe worth a shot for yours.
I had made a post to this thread regarding this but it seems to have been deleted with the new upgrade.
Anwyay...I had the same issue and it was just a matter of taking apart the switch assembly and cleaning it all. That thing gets pretty dirty pretty quick.
Discussion Starter · #10 ·
I will look into it when I get my jeep back. It had to go in for a no crank no start. Waiting to hear back on what it is or the fix that is needed. I thought about this also.
1 - 10 of 10 Posts
