Indicator light fixed-- here's how
Wife's 2005 Liberty had same problem after she was playing in 4lo to get through some snow in reverse.
After trying some other suggestions on this forum, the thing that worked in fixing the indicator light problem for us was:
- Put car in 2wd (lever all the way forward)
- Put car in reverse, got it moving to 2-3 miles an hour
- Depressed clutch, moved gear from R to neutral position
- With clutch in and while car was still coasting at 2-3 mph, moved TC lever from 2wd all the way to 4lo
- Continued back 5-10 ft
- Stopped
- Drove forward (1st gear) 5-10 feet, stopped again
- Got coasting 2-3 mph again in reverse, then depressed clutch, shifted from R to neutral, then moved lever from 4lo all the way to 2wd.
- Bingo! 4wd indicator light is now behaving as it should.
