1 - 20 of 614 Posts
This will be a long thread. With lots of pictures.
I have wanted to outboard my rear shocks for quite some time. So I did what most people I know that wheel do; go visit Blaine. I picked his brain and asked him a ton of questions, read Stu's write up and searched for a solid week on various boards. Eventually, I had a plan and the parts collected including a Currie bump stop kit. (Thanks to Gerald from Savvy, Smokin deal :thumbsup: )
Just as in Stu's write up, I started by placing jack stands under the frame to keep the frame at ride height.
Here's what lead to the whole project:
3 1/2" of up travel in the rear frankly doesn't cut it in the desert. I lived on my bump stops in the whoops. I'm aiming for 5" of up travel.
I pulled the springs and installed the Currie bump stops. All I can say about the kit is "quality". They're sweet.
A tip Blaine gave me is to fill the upper bump with washers so you are not compressing the upper edge of the cup and have something to tighten against.
http://img682.imageshack.us/i/dscn3113.jpg/
3 washers and I was good to go.
http://img682.imageshack.us/i/dscn3114.jpg/
Once the bump stop kit was installed (yes I know they are not centered, I left them loose for mock-up), I jacked up the rear end to start taking measurements for my outboard shocks....
maybe not :rofl: We have a problem Houston.
Here's the problem, I run RE super flex 2 fixed length lowers. They're long. They caused some headaches in the front but it was easily fixed by bending the Currie drag link out a bit more and using wider lower bump stops. Not the case out back since the offset is compounded by the pinion adjustment required by my Double Cardan drive shaft. I love the length of the arms, so even when I go custom arms, I want the axle to be in the same place. Gotta do SOMETHING.
So I start scratching my head, grab a cold coke, and do what most people I know do; Call Blaine :rofl:
At this point, I have to throw this out there. If you have never talked to Blaine you're missing out. He talks about jeep mods like you would tell someone how to butter toast :laugh: He's just so good at what he does, the average skilled guy (or below average like me :p) is left saying "No way I can do that." Luckily for me, he allows time for me to get my crayons out so I can follow along.
After a great chat with Blaine I'm left with two choices; Get adjustable lowers OR cut off the upper spring buckets and move them a bit back and level them.
Did I mention I like the length of my lowers?
Getting to the back welds was quite fun even with the tank removed. I ended up using a dremel with a cutoff wheel. The outside was easy with a grinder.
Still gotta do some trimming around the track bar mount and flip the track bar bolt around, but you get the idea.
From the looks of it, I will be able to get the coil mount raised up 1 1/2" while its rotated back. Hope so, otherwise I'll be in the market for some shorter springs. This is a prime example of the Jeep Cascade Effect. Set out to change 2 things, and you end up changing 100 little things. Good thing I like my garage :D
did you have to get longer shocks to do the outboarding
I will be outboarding and triangulating my rear soon. I was told that 13" Long travel shocks is what I'll need. does that sound right?
Really depends. Much over a 12" shock on short arms isnt advisable though. I'm cheap, so I went with the longest Skyjacker hydros they make. 11 1/2".
Im really just doing this as a temp fix before going to a custom suspension with coil overs. Just dont have time for all that before my next deployment, and really want to get some more trails in before I go.
I made this thread because these are pretty common mods people do and they kinda go hand in hand. Figured Id throw some pictures and notes since I didnt find a whole lot searching.
Wizard of Brakes
Great job Joe! I'm liking it so far and I thoroughly enjoy your reluctance to dive into something I well know you're capable of until a little kick in the butt sends you on the way. :rofl:
Make sure that you mock up the perches and make sure the bumps work before you weld them up. Like I said on the phone, trimming the back of the one around the trackbar mount won't be an issue.
The only other thing I would caution others on is to be careful and watch the depth of your cut on the welds. The frame is pretty thin comparatively and you don't want deep gouges in it from the cut-off discs.
Wizard of Brakes
Why did you go with the ford mounts? I think remember that Blaine recommended another source previously; I think it was the TNT customs kit which I have ready to install. I also have the Ford mounts which I bought before changing my mind.
Treks Offroad Products - TREKs Rear Outboard Shock kit
Cheers, Mike
He's not going to be running anything but the normal style shock bushings. If you run the Fox or similar style, then it's not worth the effort that it takes to modify the top of the Ford tower to get them to fit. With his normal shocks, he just has to drill out the holes to 1/2" and he's good to go.
Cutting the frame to weld in the new towers, how does that affect the structural integrity? I doubt it would cause issues for the main suspension since it is behind that area. Would it cause issues for towing? What about getting hit from the rear?
I can say that two local custom 4X4 shops would not do the job for me. So there are some knowledgable people who have their doubts. That said, I have not heard of anyone having problems on the forums. I wonder how Stu's set-up is holding up...
Discussion Starter · #16 ·
I'm sure Blaine will come along and answer this better.
I dont tow but seeing that you're basically boxing the frame with the shock tower I'm pretty sure you'd be ok with the low tow limit of a wrangler.
As far as getting hit from the rear goes, if you look at the front of your frame, there are a series of holes that form a crumple zone. I figure if I get hit hard enough to crumple my frame and push my axle forward, I'm done for anyway. For what it's worth, most the guys I know that have done this play in some pretty crazy terrain without it failing.
This project is hardly revolutionary. Guys have been doing it for years with no bad side effects. I would add that this falls into the catagory of "If it concerns you, don't do it."
Discussion Starter · #17 ·
I did a quick chop on the long end to give myself more room to rotate the buckets back. On my 2003 I ran into the frame side track bar bracket on the pass side and the cross member on the drivers rear.
Bumpstops back in. Still need to do a bit of fine tuning to get them where I want, but needless to say, theres some improvement there. Tomorrow, I'll clean them up and weld them in. I'm almost back to square 1 and can do what I set out to in outboarding my shocks. :rofl:
This could be done much faster. I'm working slow on purpose and having fun. :thumbsup:
Some Call me RockDog
interesting to see. I will be relocating my upper spring mount soon.
I'm really interested in seeing what the net difference in spring height under load will be after this. Again, great write-up so far:cheers2:
Discussion Starter · #20 ·
Yeah me too. It crossed my mind before I started. Rough country wont sell just the rear 2.5" coils, actually told me I had to buy the whole lift :laugh:
Ill go AEV 3" progressives if I need. I couldnt imagine it being more than 1 1/2" taller than what it was and Im not against an extra 1/2" in the rear if it is and I go the AEV route. Well see tomorrow :)
1 - 20 of 614 Posts
