1 - 7 of 7 Posts
Outboarding the front springs to allow for a full width Dana 44. Also it will kick the front pinion outward to allow the TF 727 and Dana 300 driveshaft to clear the trans case.
Automotive tire Wood Engineering Gas Automotive exterior
Automotive tire Motor vehicle Aircraft Tire Bumper
Wood Automotive exterior Automotive tire Bumper Gas
front pi
Looks good.
Does this kit stretch the front axle wheel base forward any?
Are the through frame bolts sleeved to prevent frame compression?
Is that front bumper from the same company or part of the same kit?
No the kit from Dave's is very well made. It does relocate the rear perch back a bit to allow for the Wrangler length springs. Yes there are spacers inside the frame to prevent collapse. The front bumper is also from Dave's and is welded onto the front mounts. Apparently making the front end stronger. In this photo the bumper was tacked in place then removed and finish welded. It goes to the powder coater now. The only ***** is that if you want to remove the front bumper you need to disco the front spring shackles.
1 - 7 of 7 Posts
