OR Fab Sport Cage [$350]
20941 20
Product Information
Price $350
Rating 4
Average Price $396.11
Manufacturer OR Fab
Recommended Yes: 18 / No: 2
Finish where the factory left off. Our Interior enclosure is designed to work with the factory soft top or hard top. Why bump your legs or fight to get in the vehicle? Made of (.120) wall tube, this kit is a complete bolt-in, installing in 60 minutes or less. You don't even have to remove the top. Makes a great place to mount add-on accessories such as CB radios, soft grab handles and overhead consoles. It comes in a black powder coat finish. Optional floor mount reinforcement kit available for addition charge.
1 - 20 of 21 Posts
Price $350
Pros Easy install.
Cons Doesnt provide true protection.
Recommended no
Comments: I gave an average since its better than the OEM junk. I got mine as a gift, save yourself time and money get a real cage.
Price $500
Pros Safer than factory cage. Beautiful to look at. Relatively easy to install.
Cons Poor instructions. Requires some effort to line up all bolt holes. Must cut into factory molding for windshield clearance. Must drill holes for dash bar. Uses grade 5 bolts.
Recommended yes
Comments: Despite the lack of an update on the website, this sports cage now comes with welded in grab bars, and some bolt on windshield brackets.
I ordered the sport cage with dash bar and spreader bars from 4wd.com, and got them in less than a week. I really like the look and feel of the sport cage.
My only complaints are mostly minor things. Installation wasn't too hard, but the instructions are a bit of a joke. I had to cut away A LOT of plastic molding for the bars to clear the windshield (not that I mind, but the instructions are rather vague in this area). The instructions list no torque specs for the bolts, so I just had to guess. Some of the bars required a bit of muscle and a few taps with a rubber mallet to line up the bolt holes, but they weren't too bad. I had to bend one of the windshield brackets to get it to line up with the cage. The shipping packaging was really well done, with all the bars wrapped in plastic, and some spray foam used to fill all the empty space in the box for padding. I wish they had supplied me with grade 8 bolts, and new bolts for the central roll bar boot (the factory one is a big security torx bolt, and I don't even know where to buy a t50(?) security torx bit, so I had to use vice grips to remove it). I also wish they'd packaged the windshield brackets seperate from the other hardware, as their paint was in bad shape when I got them, and I had to repaint them.
As I said, all of my complaints are relatively minor things which one has to learn to deal with when using pretty much ANY aftermarket (and sometimes even dealer) stuff. The cage is very nice looking, and it feels quite solid once it's all been bolted together.
Price $0.01
Pros Easy install.
Cons None so far.
Recommended yes
Comments: I don't recall the price...
Easy install.
Looks sturdy; hope I never have to load test it.
Also added the overhead streamers and the tie-ins that go to the cab floor.
Approx eight years in and cage finish still looks great.
Price $450
Pros Better than the factory protection. Cool looking. Very handy grab bars.
Cons Bolt in instead of weld in (both a pro and con, since I suck at welding). Self tapping bolts were worthless. Reused some factory hardware.
Recommended yes
Comments: I bought this to beef up the protection in my Jeep. I know it's not gonna take a serious roll, and come out in great shape, but I definitely think it's far superior to the factory setup. Installation wasn't too difficult, though cutting the plastic windshield trim got on my nerves. Older TJs don't even have that worthless trim, so lucky them. My windshield and hardtop fit super tight now (before they just plopped together without any issue), but that's not a horrible issue. The self tapping bolts were worthless, and I ended up just tapping the holes myself. Also, drilling straight holes on tubing with a hand drill is kinda tricky.
Over all I like it, and I have the cross bar, and 2 spreader bars installed as well.
Price $400
Rating 5
Pros Only bolt on but very strong. Saved my life!!!
Cons None
Recommended yes
Comments: Had this sports cage in my 03 Rubicon. I rolled this Jeep two times going 50mph for 100+ feet down 25feet. Would I have had the factory cage, I would not be here today!!! I just got my 2005 Rubicon LJ and ordered my new sports cage. No two Jeeps are the same so you have to fit any parts you put on bet OR Fab is the best. Hope I never have to use this again, but it's watching over me just in case!!!
Price $295.99
Pros Easy to install, very stout, out of the way and does not interfere with fit or function of vehicle, priced right
Cons PITA to install by yourself (would be cake with an extra set of hands getting some of the bolts lined up)
Recommended yes
Comments: I wouldn't put it in a professional rock crawler or competition rig but it seems like its 1000 fold better than the stock junk. Meant to take one hit, save your melon, then be replaced but I'd rather replace and sport cage than my melon.
Price $340
Pros No Lose of Leg room, grab handles
Cons Had to move sun visors
Recommended yes
Comments: How well a cage attached to the dash will hold up in a roll over can be debated all you want. I saw a video of a TJ taking a spill head over heels 3 times down a rock so it sold me. I don't get brave enough to try anything that might topple the Jeep, but its nice to know its there just in case. Although, the single greatest thing about it is having 'oh crap' handles... something overhead to grab on to.
Price $450
Pros Easy install, pre-finished, welded grab handles
Cons none
Recommended yes
Comments: I looked at several sport cage options (RockHard, Smitty, Poison, Etc.) The RockHard and Smitty do not replace the weak connection between the A and B pillars, and the OR Fab did. Easy to install, almost entirely bolt-on (the overhead streamer bars requires 4 holes to be drilled). Welded grab handles near windsheild are a nice feature.
Price $450
Rating 4
Pros easy install
Cons Sport cage
Recommended no
Comments: It was easy install, got the front cage, 2 steamers, the windshield bar and floor bars. The only issue I had was one of the windshield brackets was welded incorrectly so I had to cut it and re-weld it. Overall it adds some additional security to the average wheeler.
Price $330
Rating 4
Pros Great finish and overall looks.
Very protective packaging.
Cons Requires trimming A LOT of plastic.
Incredibly tight fit lead to a difficult install.
Recommended yes
Comments: Product came very well packaged, not a scratch received during shipping. Kind of a pain to unpack. though.
The bars would fit perfectly if they were unfinished. I had to wear the finish off the ends of the tubes to fit them. The tight fit also makes the adjustments very difficult. I'd recommend a ratcheting strap and a heavy hammer.
I'm not sure I trust the mounting points. I know a couple different manufacturers use the same points, but it doesn't seem very secure. The bolts along the dash are really just designed to hold the dash on, not to support the jeep during a roll. The floor kit should probably be considered mandatory.
The instructions show trimming a small amount of plastic from the molding, but in reality it's quite a bit that needs to be hacked off.
Once installed, the kit looks great. I really like the finish.
Banned
Price $300
Rating 5
Pros Well packed by OrFab, affordable, well built, nice clean welds, made in the USA, great powdercoating, looks OEM, offers more protection than factory support bars, welded grab handle, easy to install. Can be upgraded with streamer bars and dash bar at a later time if you like.
Cons Only real complaint I have is the hardware. Its just big and obvious looking. I will replace it with black torx/allen bolts asap.
Recommended yes
Comments: Rarely do I find a product that really modivates me to write a review, but OrFab is one of those investments that im really pleased with.
I was mainly in the market for a sport cage that would allow me to drop the windsheild down quickly and look good while doing it. Im not a hardcore rock crawler that needs a 30 point 600lb full cage to tumble off a cliff with. After lots of reading I went with OrFabs sport bar kit. I did it for a few reasons: Its affordable, simple, Made in the USA, very clean looking and well designed. Its also roll over proven (see http://www.stu-offroad.com/guards/sportbar/roll-4.htm).
Got mine from Northridge4x4 using a Xmas gift card that the GF got me. On top of that I got free shipping and a 10% off sale price. Total was $235 shipped :thumbsup:.
When it arrived. It was extremely well packed by OrFab. Encased in spray foam. I got winded trying to break it all free. But, that ensures that nothing is banging around in the box during shipping.
I did the install by myself, another person would be helpful, but not a requirement. Instuctions are easy to follow, its not rocket science so you could do it without them. A rubber mallet makes install a lot easier. Just tap the parts together with the mallet. Make sure everything lines up and is spaced out evenly, and tighten it all down. Took me 2 hours to install by myself - taking my sweet time.
Once installed its very solid, looks like it should have been there from the factory and gives me quick access to folding the windshield. Its also a nice step up from the weak OEM windshield supports. The welded grab handles are a huge plus that will get lots of use.
Im 100% satisfied with it and highly recomend it for the average joe Jeeper.
Price $1000
Pros If you're going to be doing some serious rockin it might just save your life.
Cons Tight fitting. Limited leg room and head room. Two man job to install. Could use a little more refinement in the design of it. Took a lot of time to install in order to get the front doors to close and the connection points didn't line up or fit correctly in my opinion. But it's the only one that I could find for my ZJ.
Recommended yes
Comments: Regardless of the cons when you lift one of these 7 in. they get a little top heavy especially with no sway bars on it. But the springs I got from Rusty's do a good job.
1 - 20 of 21 Posts
