121 - 140 of 271 Posts
07compasssport said:
i had the firestone affinitys 215/60/17 when the yokohmas arrived i was shocked at how "BIG" they looked. they are a 29" tire the firestones are a
27" tire so to me there was a big difference. for me it was well worth the money.:2thumbsup:
i guess i should have been more specific....i have the P215/65R17 Goodyear Wrangler SR-A All Terrains and to me, they don't look any smaller than your 235's.
my "65's" are a bit taller than your "60's" were (28.0 vs 27.2"), but i see that the Yokohamas would be about an inch taller than MY OEM Goodyears. being a 'guy'....I WANT MORE!!!! :D
since the wife is the primary driver she hasnt noticed a loss of acceleration or anyother factor caused by the 29"tires. when i drive it i have always driven aggresive so havnt noticed a change either. mpgs have stayed about the same.
Need new tires
Ok I put this off long as possible. I need new tires the stock size of 215/55/18 for my Compass lImited doesn't have many choices for replacements. More importantly yet, no replacements that I want.
I'm looking at the new Michelin Primacy MXV4 grand touring tire for a smooth ride and quiet ride. The noise of the stock Firestones is getting unbearable. I can't get that particular Michelin tire in a 215/55/18. I can however get either a 225/55/18 of a 225/60/18. I would like to install a bigger tire to fill the fender wells a bit more. Using the stock rim will have any issues with the bigger size tires? The spec of the 225/60/18 tire is 28.8" dia. The 225/60/18 tire is about $20 cheaper than the 55 series tire and the 55 series tire is on backorder from Michelin nationwide because all are contracted to an automaker right now. The 225/60/18 is what I'm shooting for.
The Necessary Evil
That's a nice tire! One that I considered. The 225/60-18 will fit just fine but you may drop a little in mpg but then since your mostly all freeway it may increase. It's hard to tell, I've seen no other reports on taller tires with primarily freeway miles. Where most of us lose the mileage for going taller is off the line in town and on back roads with constant turns and turn off and getting back up to speed. The 5 speed will help you off the line.
Maybe a typo but that tire according to the Tire Rack is 28.6 and it is a top rated tire.:thumbsup:
Bigger tires
Has anyone had any mechanical issues or ignition/emission issues going to larger tires wheels? I made my mind up to go with the Michelin primacy MXV4 tire on my Compass limited as stated before in previous threads stock tire is 215/55/18 I want to go with a 225/55/18 or 225/60/18 tire, they are my only choices for that tire. I agree with the information here that that either one of those tire should fit without any issues.
I called the tire rack asked some questions and told them my vehicle and what size tires I wanted and they refused to sell them! They said that both sizes are not within the parameters of the computer and that will effect shift points, ignition control, as well as federal emission controls of the vehicle. Voiding any warranties.
I find it hard to believe that that the 225/55/18 tire will not work. It's specs at a 27.8" O.D. the 215/65/17 Goodyaer Wrangler RSA which is a optional size tire from the factory specs at 28.0" O.D. I can't see how that tire will mess up the computer controls of the vehicle or the speedo calibration.
So once again has anyone had any mechanical issues going to larger tires. Just sounds a bunch of legal crap to cover their a**
The Necessary Evil
No problems but this is what you'll run into. A taller tire will will throw off your speedo and because of the electronics does affect the shift points in a very minute way. The dealer can re-cal your speedo but only up to 28" tall, that's what the Wranglers are on the Patriot FD II and optional on others.
I have absolutely NO problem with 29" tires on mine. I had my speedo recalled to the 28's and it's off about 3mph @60.
Just for the fun of it take a look at the Bridgestone Dueler H/L Alenza in a 235/55-18 and the 225/55-18 Michelin HydroEdge. I know they're not Grand Touring tire but check them out. Also, as long as they have INFORMED you that it's not recommended, they're covered. I don't understand their refusal to sell them to you. If needed, don't tell them what they're for, it's none of their business.
tire rack had no problems selling me the 235/65/17 yokos. course they didnt have/ask for my jeep info.
Hey thanks guys. Will most likely order the tires from tirerack real soon. I still don't have my made up as to want tire I will go with. With all the driving I do I prize comfort and quietness over performance. Those OEM Firestones are truly terrible for road noise. To 07compassport. Those Yokohamas Geolanders look nice and I see you still used the OEM wheel! Nice setup! Is that Compass lifted? Doesn't look like it, but your specs say a 2 1/8" lift. not that I'm questioning you. That a good choice for a lift it really isn't that noticeable.
I use a dial-up connection at home I've wanted to send pics to Gramps forever and I really don't have a good setup to get the pics to my computer. It may be best, but the pics might be crappy, to take the pics with my cellphone and email them to Gramps from the phone.
it is lifted. there are some pics somewhere on here with the yokos and no lift and some after.
The Necessary Evil
lol... i could have looked but im in the process of fillin out job apps and lookin at usajobs. thanks gamps.
Gramps might want to move this.
Decided to buy the larger 225/60/18 tires for my Jeep Compass. Should fit fine. Now is was wondering how much the speedo would be off. So I did some looking and found a simple forumla that I wanted share with everyone.
I know the stock tire is a 215/55/18 with an 27.4" O.D. the new tire will have an 28.6" O.D.
Assuming that the speedo is correct from the factory with the stock tires and rims.
The forumla is:
New tire size times a given speed all of that divided by the old size. SO.....
28.6 X 70 MPH= 2002
2002 / 27.4=73.06 actual
Now, lets say in theory I could lift the Jeep and install a set of 35" mudders
35 X 70MPH=2450
2450 / 27.4=89.41 actual Now thats huge!
This was so simple it works for any speed. O.D. for any tire should be able to be located at some place like tirerack where specs for any tire can be found.
3 MPH variance with my speedo is nothing to be concered about. Unless somebody goes with a major lift and some seroius mud tires on a vehicle changing one or two tires sizes isn't that big of a deal.
That forumla also works if a smaller tire was installed.
Bigger tires may or may not change MPG's. More torque is required to turn the larger diameter and heavier tires. Which means for fuel used to get that torque. However, once moving since the tires covers for ground because a larger circumfrunce. Which basically is a change to your final drive ratio. As above, with speedo reading 70 MPH it's actually 73MPH. So, to go 70MPH the speedo will read 67MPH. With gearing not changing 67MPH will create lower engine RPM, saving possible fuel.
People who notice a sluggishness from installing larger tires come from both of these factors. At 60MPH the larger tires require more torque to turn yet the engine isn't turning as many RPM now so the engine is putting out less torque and horsepower and tires are needing more. It's a double whammy! It's true and can be noticeable.
Theres your physics lesson for today!
I can't give a spelling lesson, though. hehe
The Necessary Evil
This is fine where it is. I think we may have gone threw this stuff before but it all gets lost in the longer threads (still better than having 20 short threads tho). Here is a handy calculator at 1010 Tires.
Don't forget your gas mileage will read "short" too because your odometer is showing fewer miles than it should.
New tire diameter divided by old tire diameter = multiplier
(28.6/27.4=1.04)
Miles shown on odometer times multiplier = total miles
Total miles divided by gallons used.
WHAT?!
New tire choice available for you 215/55/r18 guys
Gents, I had to replace the horrible Firestones on my Caliber two weeks ago. If any of you have ever looked on Tire Rack, you've seen the wonderful quality stuff that's available in that size. </sarcasm> Anyway, there's finally a new choice available in the way of some Yokohama Avid TRZs in 215/55/R18 form. They're a touring tire and are supposed to wear better I think. So far, I am in love with them, the ride is better and they're quieter! No rain or snow (obviously...) driving in them yet, but I like them better than the Firehawks when they were new. As an FYI, I AM NEVER buying another Firestone POS after those things... My A/Ts on my Wrangler are quieter than them things, not to mention that ALL 4 were cupped... :brickwall:brickwall:brickwall And No, I do not work with Yokohama OR Tire Rack. Final FYI, its a touring tire, so...
Tire choices
This is the first I posted since getting my new tires. Tire rack is a great place to shop, prices are all but impossible to beat. They also know their products. Anyhow, ifthey is a very limited amount of tires available in the 215/55/18. If you don't mind to change size there are many other choices in a 225/55/18 or even a 225/60/18 in you want to go bigger.
Gramps should take a look at this and move it the tire/wheel thread from previous posts. To CoroilisSTROm, go there and read the posts it's very informative.
The Firestones are junk they are so noisy and mine also cupped. I just installed Michelin Primacy MXV4 in a 225/60/18 they are a grand touring tire. Just awesome so far! So smooth and quiet. Knowing that the speedometer and odometer are off slightly due to the size increase I haven't noticed a change in MPG and they fit just fine.
I like the Compass a will always by American made vehicles but it is frustrating how much they nickle and dime and cut corners. That Firestone tire is crap. The price is cheap compared to even other tires in the same size. It's seems Chrysler brokers the cheapest price possible for tires, to bad the quality suffers as a result. The Firestones compared to the Michelin tire I just bought, it doesn't seem like there could be a wider difference in quality. It's as clear as night and day the difference between these tires.
Anyone with the 18" rims a tires should think about changing tires, you don't realize how bad they actually are! I think everyone should also complain to Chrysler. If Chrysler values quality and safety, you would think they would have wrapped the Compass and Patriot SUV's in something other than Firestone tires. Firestone tires ans SUV's don't seem to mix.
WHAT?!
Firestone tires and SUVs don't match
To quote my beloved Wolfgang in my avatar, "Oh Snap!"
How many wheel/tire options are there for the Compass from the factory? Are they dependent on model (ie, Sport vs. Limited) or are they a separate package?
If I recall, my Sport (2008) has 215/65-17 Goodyear Wrangler SR-A. Are these considered lower rung than the Firestones, since they're on the Sport? How do people generally feel about the Wranglers? Even though they get thoroughly trashed on the reviews at tirerack.com, I've been very happy with them. They might be a little loud on the highway but I've never had a car that handled so well in the snow.
