I want to convert an airconditioner to oba.. That much i have figured out, less some fittings, on my 95 YJ.. What i am curious about is I have 4 steel and one aluminum Medical O2 cylinders. I want to take the aluminum tank and mount it under the chassis next to the frame rail above any possible hits. Where it would be safe, and perhaps install a skid plate just in case.
Here is the question. I want to pump it up to about 250-300 lbs which is just a little less than the capacity of the OBA compressor. Can I tap into the side of the tank to put in outlets IE> Limit valve, drain valve etc. and perhaps even a tap for the rear of the Jeep. I know i can do this on a steel tank with a little welding, but not sure on the ALUM. tank.
I want to use the aluminum tank because it is way lighter and doesnt rust. sooo minimial maintence..
Thanks
Thanks
