1 - 6 of 6 Posts
I've been working on my new dash and installing new gauges, dash lights and pulls. I've purchased a new oil pressure sensor, as well as, a oil pressure gauge, but unfortunately the previous owner hacked up the wiring. What wires do I need to connect the two together? The gauge has a small black and red wire. I need some idea of what wires I need and where they go. I want to just start over if possible. Thanks for any help.
I colored a 1979 wire diagram from a manual
Sometimes the wiring is the same (or close to) in other years
I also have a 1977 CJ-5 (and a '46 too!)
These diagrams may aid you (or not!) The fuse boxes are different
See Posts 2-4 in this link Lights/Main Power Wire... HEI Set up
I like these old style diagrams since you can follow them like a map!
Don't have a 1977 Factory Manual????
Check out my signature below
------JEEPFELLER
Is it a Jeep gauge or an after market one? I have replaced all mine with after market gauges and they all have a black wire that goes to ground and a red one that goes to switched power. You should have a third connection for sender input. I haven't looked at the wiring diagram on JF's referenced site, but the 74 has a diagram and a Rosetta Stone color code list of which wire goes where.
Good luck!
1 - 6 of 6 Posts
