1 - 20 of 69 Posts
Hello,
I overfilled my oil and feel pretty silly about it.
Discovered the problem when oil was leaking out of the dipstick after she was warm, I did not drive it.
Got the oil to the proper level.
Plugs were fouled and I found oil in my distributor.
There was a light coating on the inside of the cap but enough had moved around in there to cause it to be noticeable from the cap vent and a very small amount collected in the base.
Replaced the plugs.
Cleaned the distributor and inside of the cap with electronics cleaner, cotton swabs, and compressed air.
She started right up and ran until warm.
I shut her down and could not get her restarted.
Plugs are ok.
I am going to pull the cap off and clean everything up again tomorrow.
If she starts, runs, and won't start again, my instinct is that I blew the o-ring in the distributor.
Am I on to the right thing here?
Should I rebuild or replace if it is the o-ring?
I am running an MSD 8516.
Geeze Louise am I feeling sillier by the moment but this site is about learning.
Going to get a new PCV and a thought crossed my mind about a different potential problem.
I have a flexible pipe attached to my exhaust and then attached to a shop fan on high. Could this be causing a problem? Back pressure or something?
I am still going to replace the PCV and clean the distributor again before I try to start her again.
Check for spark?
Fuel?
The PCV is good, tested for spark, good.
Not getting fuel into the carburetor. Pulled the inlet hose on the barb and I get fuel when it turns over. When reconnected, no fuel coming out of the jets.
I sprayed some carb cleaner into the carb and inlet barb. No cleaner came out of the jets when I sprayed it into the barb.
No start.
Is it possible that the oil issue did this to the carburetor?
If so, any tips for cleaning it before I rebuild it?
I have a Weber 38DGAS.
By the way, the fan theory did not work. I had to ask.
Maybe a shot of starter fluid down thru the carb?
----JEEPFELLER
Reactions: michael72
No start.
I think it's more likely the oil damaged the mechanical fuel pump.
Discussion Starter · #9 · (Edited)
I tried starter fluid, no dice.
If I pull the fuel line off of the carburetor and turn the key, fuel is coming out.
I think that means that the fuel pump is working.
I cannot see anything coming out of the jets in the carburetor, no fuel when the line is connected and the engine is turned over, no carb cleaner when I spray it into the inlet barb with the fuel line disconnected.
Can the oil have caused this problem?
Forget the oil in the distributor for now.
You won't see fuel out of the jets. What you want to do is pump the throttle and observe to see if there is fuel squirting out of the accelerator pump nozzle.
If so then you have fuel as well. If not, you may need to pop the carb lid and see if the needle valve is stuck or an obstruction in the inlet. You also want to see if there is fuel in the float bowl.
If you have fuel and spark, then you may be looking at a flooded situation, both the cylinders and plugs.
Discussion Starter · #11 ·
----JEEPFELLER
Thank you.
That make sense.
I think that I have ruled out the distributor now.
Going to do Friday night stuff and hope to get back to it tomorrow.
I really appreciate this.
SPARK?
Several ways to test for it.
This seems to be the accepted old time way.
I used to pull a plug to perform this test-----then it struck me, pull the wire off, and use a old/ or on hand plug for the test. A "same kind" plug will show the correct spark (I found that other plugs for other rigs may show weaker sparks).....Moral? Buy an extra plug, so if you ever break one, or you need it for this test!
I'm thinking ignition,
My test above will show what to look at next
With no spark, these are a few possibilities.
Wires loose
Bad ignition module
Bad coil
etc.
For me, the module or coil would be an EZ test/ or even fix----I keep spares of a lot of items, the coil, module, and the fuel pump have left me stranded in the past (over years-in other CJ-5s)So I keep them and tools on board all of the time. Luckily it's been a while for me, but I have helped a couple of other CJs in need of a fuel pump, the other with a module.
----JEEPFELLER
Discussion Starter · #14 · (Edited)
JEEPFELLER,
I tested for spark and am good to go.
Jeepdaddy2000 recommended that I take a look around inside of the carburetor.
After a few epic battles with the Carter BBD, I replaced it with the Weber about 18 months ago.
Since I haven't had any problems with it, I don't know the insides yet and am going to take my time to do some learning.
I am going to see what is going inside of the carburetor tonight and let you know.
Discussion Starter · #15 ·
Pulled the top off of the carburetor.
Didn't see any glaring obstructions.
Cycled the accelerator diaphragm, I did see bubbles in the fuel.
Cleaned whatever I could.
Great diagram for a Weber 38.: https://www.carburetion.com/diags/38DGASDiaginfo.asp
Put it back together and am now getting fuel coming out of the "Air Corrector Jet?" (# 94 on the diagram) and splashing out.
I have three theories:
1: There was an obstruction that I cleared and then put the carburetor back together incorrectly.
2: There was an obstruction that I cleared but the fuel pump was damaged when the oil was overfilled and is putting out the incorrect pressure. I went and picked one up if I decide to get after this again tonight.
3: I pulled the carburetor and put it on the shelf for six months. Could residual gas have caused a problem?
Thoughts or advice would be much appreciated.
When your carb was together and installed
Did a 2 second shot of starter fluid OR 2 teaspoons of gas down the carb's throat do anything? Spit? Sputter? Run a few seconds?
Nothing at all---just dry over and overs?
Even if the carb was not letting fuel get through it----You adding it down the throat should have done something.
----JEEPFELLER
Discussion Starter · #17 ·
She started, ran, and warmed up three times.
First time, would not restart.
Second time, discovered too much oil and shut her off.
Third time, replaced plugs, PCV, and cleaned the distributor. Would not restart. Re-checked for spark and fouling, OK.
Before I took the carburetor top off, I cranked the motor. I did not have any gas in the bowl.
I am going to keep messing with the carburetor but I have two questions:
Since I pulled the carburetor off and put it right on the shelf, could the residual gas have caused some damage that requires a rebuild? I was concerned with the bubbles in the float bowl when I actuated the accelerator pump.
It was mentioned that the fuel pump may have been damaged, can it be damaged and producing too much pressure?
We just got a snowstorm so I am going to shovel and try to forget about this for tonight.
Thank you again.
How's things a goin' boss man?
---JEEPFELLER
Discussion Starter · #19 ·
Oh geeze, it took me a minute to see the fuel pump in the picture. Awesome.
I have had to do some work for my grownup job for the past few weeks, I should be getting back to it this week.
Update from my last post:
- I fixed the fuel shooting out problem: I connected the inlet hose to the bowl vent. Might as well be honest.
- I bought a borescope to check on a suggestion that the engine may be flooded internally. I have only used it to look under some stuff in the house, looks great so far. Works with my cell phone and was $36. We had a specialist with a suitcase that used the borescope when I was in the Air Force, I figured it would be a fortune, if you ever wanted one, they are cheap now.
Kinda about where you at shoveling snow (don't have to get real specific)
Any progress with the carb?
That is my spare fuel pump for my '46 Willys---a few years ago CSE OFFROAD (Somewhere in NY) Had them for $21.00 Each-----I snagged 3 up, normally they are well over $50. Never hurts to have a spare or two, my buddy decided he would leach in and take one for himself. Now it's one on my engine one for a spare.
I enter a Willy Jeep catalog contest every year (4 pics allowed) The idea is to "win" the front cover ($1000 gift certificate) Back cover ($500 GC) or one of 12 calendar pages ($100 GC).
I try to do "unique" shots, things no one would think of----that toy Jeep and one of my #2 grandson just didn't cut it that year.
The closest "I" got was I submitted my pics, then told a friend about it. My #1 grandson and I visited him in a few weeks. He and my grandson posed with his unrestored '43, I took the pics. He submitted his 4, and won the back cover! He gifted in a whole bunch of things he will definitely need-----It's been 6 or so years, he hasn't touched his Jeep.
His dad bought it surplus in 1946, it's been sitting there in the garage since 1974.
Here's the $500 shot I took for my buddy---Lent out my grand-youngin' to boot!!!
Post where you stand with your Jeep!
Gettin' anywhere?
----JEEPFELLER
1 - 20 of 69 Posts
