I'm getting ready to replace the rockers and the rear web between the rockers and uniframe rails on my '02 Jeep WJ.
The rocker panel replacement I've ordered is the Spadano Enterprises ROCKer Sliders. For the web I'm having to fabricate something as that parts not available anywhere.
Fairly simple design, and I've knocked out the bulk of the design and build for one side in less than an afternoon. The original piece had an oval hole with dimpling around it. The dimpling caused sand and salt to be trapped inside, resulting in that being some of my worst rot.
My plan is to punch an ~ 2" hole or 2 in the bottom facing side of the piece to facilitate flushing the area with water to wash out any sand, salt, or other debris that may work their way inside there.
I'm debating whether I should dimple those holes or not. I'd have to order a set of dimple dies, and they'd have to be bolt driven, as I don't have a press, or even room to put a press(or else I'd have one.)
So the question is: No dimple, Dimple up, or Dimple down?
