No spark? Lets troubleshoot.......I put the plugs back in and cranked but didn't get a hint of fire. Holding the coil wire close to the body I didn't get any spark, so I ordered a new coil along with a set of wires. There is a hot wire going straight from the hot terminal of the battery to the + side of the coil due to the generator being disconnected.
I removed the distributor cap and everything looked surprisingly good inside, which I was thankful for. I think if I can figure out how the distributor is clocked I'll be in good shape to test fire it with some gas down the carb.
This is where I get to learn all about points and distributors. :wink2: Most of my auto experience is with mechanical diesels and fuel injected gassers.No spark? Lets troubleshoot.......
Use a test light.
Remove the ignition wire from the coil and turn the key on.
Do you have power at the wire? If not, then you have an issue between the battery and the coil.
If so, install the wire back on the coil and remove the wire from the dist side. Do you have power at the - coil post? if not, you have a coil issue.
If so, reinstall the dist wire and open the points. Do you have power at the point arm? If not, then you have an issue between the coil and the points.
If so, then file and regap the points. You should have spark every time you open the points with your finger. If not, check the points ground and the condenser.
The dist connects to the oil pump with a beveled drive. It will only go back one way. You will need to readjust the timing once you get it stuck.
I'll do some research on that. Looks like a good conversion.Now would be a good time to replace the points with a Pertronix electronic ignition. It isn't expensive and easy to do.
I really can't stress this enough, but everything inside the distributor looks brand new. Like it was replaced 25 years ago and run for maybe an hour before being parked. If I still don't see spark at the plugs after this I'll definitely be tearing into it.Ok, for the points/condenser, just order a new set rather than mess with what you have. There should be a tag on the distributor with the brand and model on it, you will need to make sure that you order the right set of points. Once you pull the cap and rotor, the plate that the points are mounted on removes after you take out the two screws that hold down the catch/latch for the cap. Once you have the screws out, the plate will lift out of the distributor. There are 2 screws in the points, one holds them in place, the other is a cammed head that adjusts the gap. Do not turn the one that is in the oval slot on the points (gap adjustment), just take loose the other screw and the lift the points off of the pivot pin. The new set of points should be close enough to drop back onto the plate and put the holding screw in and get the engine to fire up, you can fine tune the point gap later. the 'ground' wire from the coil connects to the points and spark occurs when the points open. make sure the you also replace the condenser, this absorbs the extra voltage when the points open and close to llimit the spark between the points as they open and close to extend the life of the point contact surface. if the condenser is bad, it can short directly to ground and the points will never charge the coil to get a spark.
Ok, that's good to know. Do you know which position should be for cylinder 1? This little diagram isn't much but it might be accurate anyway. Looks like cylinder 1 is likely pointing toward the front of the engine.The distributor on the F-head has a flat drive and timing limited adjustment so as long as the oil pump gears are timed correctly to the cam you should be close on the timing. so #1 can really only be in 2 positions with that distributor. no being 'teeth off' when you put in the distributor.
This is the distributor drive, so unless someone has had the oil pump gears off, it can really only go in one way.Thanks for that. At least I have somewhere to start. If I don't have any luck in that position I'll just rotate the wires 90 degrees until I find it.
Right, I just have no way of knowing whether it has or not. I'm just gonna assume it hasn't been and see how it goes, hopefully tomorrow.This is the distributor drive, so unless someone has had the oil pump gears off, it can really only go in one way.
This has really piqued my interest. Between the Pertronix and a complete solid state distributor which do the members here prefer? Seems to be the Pertronix, but I figured I'd ask.Now would be a good time to replace the points with a Pertronix electronic ignition. It isn't expensive and easy to do.
Pretty sure we just pulled the battery cable to shut it off, IIRC. But yes, the only function the key would serve in this setup would be for the accessories and starter solenoid.BTW, If you have the coil connected directly to the battery, you might have trouble shutting it off after it starts.
Someone may of done that just to try starting it some years ago.
I would have to check the schematic but it's likely you will also need a ballast resistor so you don't burn out your ignition coil.
and this would be more useful than the other one.
