Bigbob, got any numbers for me? Well finally got on SketchUp today and here is what I have before lunch will work on it a little more after I get back but had some questions.
Sorry about that.
I noticed that you have a small section of tubing on the inside right where the spring mounts are. Is this because the mounts for the springs were larger than 2" to fit on the tube or for gusseting?
Actually that was a screw up! I wanted my center to center of the frame rails at 44" which is similar to the Jeep. But the way my axle is built with the lowered replaceable spindles I could not make the springs center to center at 44". Instead of narrowing the frame I added the piece. The springs are 42: center to center. It does add some strength to the spring area. And being I cut out the frame rail for the shocks it was a good idea.
Also what size tube is your tongue made out of it looks like it slides in real well. You said your using 2x2 with 1/4" walls that would make a 1.5" ID. I have heard everywhere that you shouldn't pick your OD real close to your ID when telescoping. Is that a 1.25" OD tube and what thickness?
The square tube piece I used in front, like you have in your sketch up, is 2.5" OD 2" ID tube. I used regular tube which has a ridge in it. You can buy receiver tubing which has no ridge, but it is a little pricey. In retrospect I should have bought the receiver stuff as getting the 2" stuff in is hard with that ridge there. I ended up cutting a 1/32" groove in the 2" stuff so it would slide easy. So it is a 2" 1/4" wall tube in a 2.5" 1/4" wall tube. I have no 1.25 tube anywhere.
Oh and one more. You only paid 40 bucks for all that steel?! Where did you get it, that is a steal.... I really didn't mean to rhyme.
No, I was being funny. But if you are talking about the comment in regard to the frame being built and the tires and wheels mounted the $40.00 is not terribly off. Right now the place I buy remnants is about $.70 a lb. At the time I bought the tubing it was $.60 a lb. They only have remnants in 10" or less lengths.
So my frame is 2"X .120 wall square tube. The center to center of the frame is 44", 46" outside. The frame length is 60" and the tub/frame width is 64". The tub height behind the wheels is 20" and forward height is 21.5". The tailgate is also about 44" IIRC, may be and inch different more or less.
