TL;DR, I bought an 08 Liberty KK from the dealership about 6 months ago. The original owner had a remote start system tied into it, and when he sold it, decided to just snip the wires and remove it unprofessionally. For the first few months, everything was fine, but then progressively over the months, "possessed jeep syndrome" sets in and the horn goes on raging, front and rear windshield wipers go on, and the windshield fluid decides to start ejecting.
I've read around, i've done quite a bit of research, and everyone says its either the TIPM or the Clockspring...
Long story short, i'm replacing both of them this weekend, but at the same time, while I was pulling apart the steering column,
I've identified that the wiring harness which runs from the clips near the firewall, all the way tied into the steering column, and part of it continuing on back behind the radio....
I'm trying to figure out exactly what wires are stock configured and which wires were "reconfigured" for the erroneously installed remote starter.
As you will be able to see with the attached pictures, a lot of the wires are covered in non-factory electrical tape.
Theres some other areas which look like theyve been wrapped with heat-bond insulation tape.... which im also unsure if its factory.
So, fellow jeepers...
A) Does anyone have a wiring diagram of the wires that go thru / should be in this area? if i could get a diagram of how the clockspring is wired, and the color configuration of these wires, I might be able to figure out what is factory and what is not.
B) Attached to the ignition control module (im not sure if this even is an ignition thing? i just know it plugs into the clockspring...), there is a purple/gray wire which goes from the connection plug into the wiring harness... then on the wiring harness, there seems to be a wire which was bonded onto this wire, to create a y pigtail...
Part of the previous remote start system was attached went to this wire.... but I'm thinking it was seriously modified by the installer.
C) From these attached pictures... Does anyone see anything that IS DEFINATELY not from the factory?
Can anyone help me figure this out?
The car is not running now and im literally throwing everything I have at it.... she only has 65k miles
