I got a key made without said code Nd.Anyone here able to lookup my 2004 grand cherokee ignition pin code via vin number to save me a trip to the dealership? I only have 1 key and need the code to make another.
Thank you
Tom
A key made from 1 existing key will be a "clone" key and won't be able to use the His and Hers dual settings if your WJ has them.
That said, the key will work fine.
My WJ has the dual memory settings based on which key you use and I never use it.
DOH!No such thing as "His and Hers" dual settings in the keys. Memory 1 & 2 are set and controlled on the driver door panel.
What does the "Fob" look like please Me?The black and gray fobs are both the same and can be programmed to any of the slots. The color and # are for nothing more then visual identification. There are 4 programming slots on the WJ. Fobs programmed to slot 1 and 3 are memory position 1 and slots 2 and 4 are memory position 2. The PIN code is only for programming keys in to the SKIM. The fobs are programmed in to the passenger door module no PIN needed.
Where I come from
a "Fob" is summat attached to a key.
Thanks MeWJ uses the FOBs pictured above. The only thing they attach to is a key ring.
I need to program a keyThe black and gray fobs are both the same and can be programmed to any of the slots. The color and # are for nothing more then visual identification. There are 4 programming slots on the WJ. Fobs programmed to slot 1 and 3 are memory position 1 and slots 2 and 4 are memory position 2. The PIN code is only for programming keys in to the SKIM. The fobs are programmed in to the passenger door module no PIN needed.
I.dont beDoes the pin expire? I bought a key five or six years ago but didn't have it coded but I did get a pin at that time. I thought somebody mentioned once that they expire and you have to get a new one if you don't use it within a certain amount of time.
My obd2 scanner says it can so i thought why not try lolMaybe the person who mentioned it was thinking of a newer vehicle. I am wondering If I can program the key with a good scan tool?
It's actually "fob", a word, not "FOB" as an acronym. Historically, a fob is an ornament that attaches to a watch chain or keyring - hence fob watches, those watches that attach to a chain and live in a pocket in a waistcoat/vest.WJ uses the FOBs pictured above. The only thing they attach to is a key ring.
