1 - 13 of 13 Posts
i have an old cj5 but thats about all i know. The serial number on the firewall is 10C 11024 and engine serial number is 4J394613. if anyone could help me out with a year that would be great
1974 Jeep CJ-6
If the engine is original, then it is a 1965 or 1966. The 4J in the engine serial number signifies gasoline F-Head pre 1967 and I found reference to a 1965 with engine number of 4J383887 and a 1966 with the engine number of 4J405443
Can you check on the firewall number again? 10C in the first part of the serial number would be diesel powered built in Canada. If it was originally diesel, the serial/vin tag should begin with 8310 C. If you have a Canadian built diesel early CJ-5 you have a rare one.
serial number range for diesel early cj-5's
CJ-5 serial number for the ’61 CJ-5 was 10,001 and the ’68 model year started at 11,156
https://jeepwillysworld.com/wp-content/uploads/2014/02/Vehicle_Indentification.pdf
1974 Jeep CJ-6
Yep, looks like a factory perkins diesel powered made in canada early cj5. Congrats on having a rare one, sorry I can't give you a better guess on year other than from 1961 to 1968.
Haven't seen may canadian serial number tags so just having 10 C threw me off.
when i look up the serial number with the insurance company it says its a 1949 jeep so must be a 49 body with newer engine?
1974 Jeep CJ-6
It is not a 1949, CJ5 production began in 1955. The insurance co can not go by the serial number without also having the model code.
That prefix of 10C signifies that it is a diesel powered CJ5 between the years of 1961 and 1968. There is not a comprehensive breakdown of serial number by year for that diesel powered model.
1981 Jeep CJ5
Pics of engine, and the rest of the rig?
Discussion Starter · #9 ·
No longer has diesel engine. Has a gas with serial number listed above. Would like to know engine code or size to make it easier finding parts
1981 Jeep CJ5
Near ready for the parade right there.
Diamond in the rough :)
Hi older cars/jeeps/trucks had the year stamped in the tail light lens. you should be able to find it there.. yes NOT a 49.. Jeeps in the forties had flat fenders with no curve down in the front.
good luc
tim
1 - 13 of 13 Posts
