While replacing a dead battery I found that my negative battery terminal was missing the little clamp you see in the attached picture. It's purpose is when you tighten the nut it puts pressure on this little clamp which secures the connector to the terminal which you can see in the linked video. Because this clamp is missing my negative connector is loose. Can anyone share the part # with me or help me find a replacement to buy?
I went to 2 dealers locally here in FL - The first gave me a different style connector which would require replacing the entire existing connector versus just the little missing clamp. This would require significant work and is not the solution. The second said the only way I can get just that clamp is with an entire replacement cable or wiring harness which is also ridiculous. I also haven't found a replacement on OEM parts diagrams.
Please let me know what you think any help is appreciated.
