1 - 3 of 3 Posts
Hello. I am a newbie to this group. Very pleased I can join. My baby has carburetor leak.
Potential mechanic asking me engine size (litres). I have no clue.
Where do I look on engine?
It is a 1978, CJ5, V8 AMC/Renault.
Does anyone know the litre size of engine?
And where can I get replacement part.
Thank you so much in advance.
(I did a brief look at past posts but do not see anything that matches. Apologies for new thread if this info is already out there.)
1974 Jeep CJ-6
The engine displacement should be cast into the block. Facing the front of the Jeep, the number should be under the right side motor mount. It will likely be 304/5.0 Litre. It may also be 360/5.9 Litre. The 304/5.0 Litre would be the stock motor, the 360/5.9 Litre would be a swap. Also if the factory valve covers are installed, there should be a number tag screwed to one that can also be used to identify the motor size.
You should be able to easily get a rebuild kit to fix your leak.
I'm sure it is a 304 with a t150 3spd manual and a dana 20 transfercase. If you can stomp on it and do wheelies you might have a 360 or 401 swapped in:smile2:
1 - 3 of 3 Posts
