First, a bit of background. My rig is a 2004 wrangler unlimited which I bought new back in 2005. This is my 4th Jeep. My first car was a 1971 CJ5, with the 225 Buick Dauntless, Odd Fire V6. It would pull the front wheels off the ground going forward - and pull the side wheels off the ground going around a corner. It was a death trap - but you don't know that when you are 16.
Here is a pic - my sister always called me a Jeep Creep - so the name stuck. Since this rig, I've owned a 1982 CJ7 Laredo, and a couple of Cherokees. But I had been out of Jeeps for a while, before deciding to get back into it with my current rig.
EDIT: I've been meaning to add an Index to this thing to help me locate and reference the large mods I've done. I'll add to this list periodically.
Coilover Suspension..................................... Post #5
Front Stretch - TMR Stretch Kit - - - - - - - - - - Post #683
Coilovers, 115" Stretch - First Pics - - - - - - - - Post #795
RTI Ramp Comparison - - - - - - - - - - - - - - - - Post #836
Control Arm Welding - - - - - - - - - - - - - - - - - Post #863
Train Horns - - - - - - - - - - - - - - - - - - - - - - - Post #880
A/C Rebuild and Recharge - - - - - - - - - - - - - - Post #901
Moab 2017 / Golden Crack Flex Comparison - - - Post #917
Tranny Cross Member Rebuild - - - - - - - - - - - - Post #973
Kenwood Double Din & Lowrance HD7 Install - - Post #1008
Power Steering Pump Pressure Valve - - - - - - - Post #1055
Catch Can / Aluminum - - - - - - - - - - - - - - - - Post #1057
392 Hemi - First Thoughts - - - - - - - - - - - - - - Post #1070
5.7 Ram Hemi Delivered - - - - - - - - - - - - - - - Post #1097
392 Hemi - The Build Begins / Teardown - - - - Post #1101
Suck Down Winch - - - - - - - - - - - - - - - - - - - Post #1121
Busted Knuckle OffRoad Park - - - - - - - - - - - - Post #1169
Data 60 Axle Shaft Carnage - Laser Cut - - - - - - Post #1173
Polk Speakers - Front and Rear - - - - - - - - - - - Post #1175
Axle Shaft Repair - - - - - - - - - - - - - - - - - - - - Post #1179
ATS 545RFE Tranny Received - - - - - - - - - - - - - Post #1206
Subwoofer Repair - - - - - - - - - - - - - - - - - - - Post #1216
Golden Mountain Off Road Park - - - - - - - - - - - Post #1229
Trailer - Drive Over Fenders - - - - - - - - - - - - - Post #1246
392 Hemi - Assembly - - - - - - - - - - - - - - - - - Post #1291
392 Hemi - Build Complete / Ready for Install - - Post #1434
Easter Jeep Safari - 2018 / Pritchett Canyon - - - Post #1437
392 Hemi - Installation - - - - - - - - - - - - - - - - Post #1453
392 Hemi - Exhaust - - - - - - - - - - - - - - - - - - Post #1588
Hood Louver - But not why you think - - - - - - - Post #1697
Dyno Tuning - Take 1 - - - - - - - - - - - - - - - - - Post #1713
Bigger Cooling Fan - - - - - - -- - - - - - - - - - - - Post #1751
Belly and Engine Skid Modifications - - - - - - - - Post #1781
Exhaust - Back Half - - - - - - - - - - - - - - - - - - Post #1797
Welder Idle Control - - - - - - - - - - - - - - - - - - Post #1830
A/C / Take 2 - - - - - - - - - - - - - - - - - - - - - - - Post #1841
1350 Driveshafts - - - - - - - - - - - - - - - - - - - - Post #1860
Cowl Intake - - - - - - - - - - - - - - - - - - - - - - - Post #1863
Oil Separator - - - - - - - - - - - - - - - - - - - - - - Post #1887
Dyno Tuning / Take 3 - - - - - - - - - - - - - - - - - Post #1903
Dyno Pull - - - - - - - - - - - - - - - - - - - - - - - - Post #1904
Motorfest Car Show 2018 - - - - - - - - - - - - - - Post #1915
Backup Camera - - - - - - - - - - - - - - - - - - - - Post #1923
1350 Front Driveshaft - - - - - - - - - - - - - - - - Post #1935
Long Travel Spare Front and Rear Driveshaft - - Post #1939
Tailgate Organizer - - - - - - - - - - - - - - - - - - Post #1977
Wooly's Offroad Videos - February 2019 - - - - Post #2016
Driver's Seat Fold and Tumble Actuator - - - - - Post #2057
Monster Valves - - - - - - - - - - - - - - - - - - - - Post #2068
Monster Valves Speed Testing - - - - - - - - - - - Post #2075
Cancer - - - - - - - - - - - - - - - - - - - - - - - - - Post #2105
Inner Dana 60 Axle Seals - - - - - - - - - - - - - - Post #2155
AOP New Years Day 2020 - - - - - - - - - - - - - - Post #2187
Caffeine and Octane Jeeps - January 2020 - - - Post #2196
Powertank Mount - - - - - - - - - - - - - - - - - - - Post #2211
PSC Hydro Assist Redeaux - - - - - - - - - - - - - Post #2317
Custom Windshield Washer Pump & Reservoir - - Post #2354
Wooly's May 2021 - Goodbye Krawlers - - - - - - - Post #2376
Cooling Fan Controller Switch Mod - - - - - - - - - - Post #2427
Maxxis Razr 40's - - - - - - - - - - - - - - - - - - - - - Post #2440
Colorado BDR ADV Bike Trip - - - - - - - - - - - - - - Post #2485
A/C Leak Repair - - - - - - - - - - - - - - - - - - - - - - Post #2488
Trailer Ramp Modification - - - - - - - - - - - - - - - - Post #2500
Body Mount Replacement - - - - - - - - - - - - - - - Post #2521
Team Hunt Overlander Ladder Mod - - - - - - - - - Post #2559
The Real LJ - - - - - - - - - - - - - - - - - - - - - - - - Post #2581
Smoked Rear R&P and ARB Locker - - - - - - - - - - Post #2584
Pro Rock 60 Rear Gear and Locker Setup - - - - - - Post #2643
14 Bolt Build - - - - - - - - - - - - - - - - - - - - - - - - Post #2724
Shaving the 14 Bolt - - - - - - - - - - - - - - - - - - - Post #2783
Straightening the 140 Bolt - - - - - - - - - - - - - - - Post #2811
14 Bolt Truss - - - - - - - - - - - - - - - - - - - - - - - - Post #2828
14 Bolt Gear Setup - - - - - - - - - - - - - - - - - - - - Post #2859
14 Bolt Install - - - - - - - - - - - - - - - - - - - - - - - Post #2894
Fuel Tank Tuck - - - - - - - - - - - - - - - - - - - - - - - Post #2912
ProRock 60 Front 8 Lug Conversion - - - - - - - - - - Post #2933
Swing Away / Swing Down Tire Carrier 8 Lug Mod - Post #2958
GMRS Radio - - - - - - - - - - - - - - - - - - - - - - - - Post #2988
Bent Tailgate Correction - - - - - - - - - - - - - - - - - Post #3015
Moab 2021 - TJ Fest - - - - - - - - - - - - - - - - - - - Posts #3027
Roadside Trailer Repair - - - - - - - - - - - - - - - - - - Post #3038
Moab TJ Fest GoPro Video - - - - - - - - - - - - - - - - Post #3059
AOP April 2021 - - - - - - - - - - - - - - - - - - - - - - Post #3074
Colorado BDR in the Cherokee - - - - - - - - - - - - - Post #3093
Hydro Steering Mount Repair - - - - - - - - - - - - - - Post #3109
Northeast BDR ADV Moto Trip - - - - - - - - - - - - - Post #3117
Door Surround Removal Mod - - - - - - - - - - - - - - Post #3122
VanLifeDesign Picture - - - - - - - - - - - - - - - - - - Post #3132
Tuning the 392 - Take 2 - - - - - - - - - - - - - - - - - Post #3137
AFR Gauge Installation - - - - - - - - - - - - - - - - - Post #3138
Laptop Desk for Data Logging - - - - - - - - - - - - - Post #3175
Hawk Pride Off Road Park - September '21 - - - - - Post #3152
AOP - September '21 - - - - - - - - - - - - - - - - - - Post #3164
Driveshaft Carnage - - - - - - - - - - - - - - - - - - - Post #3168
Top Repair - - - - - - - - - - - - - - - - - - - - - - - - - Post #3175
Antenna Replacement - Chrome No-Mo - - - - - - - Post #3181
Trailer Tires - - - - - - - - - - - -- - - - - - - - - - - - - - - Post #3184
Driveshaft - Beef Version for the Rear - - - - - - - - Post #3185
Higher Volume Radiator Fan Needed - - - - - - - - - Post #3199
Spal 500 Watt Brushless Fan Install - - - - - - - - - Post #3207
Hidden USB Connector - - - - - - - - - - - - - - - - - Post #3226
A/C Fan Override Wiring - - - - - - - - - - - - - - - - Post #3230
Band Saw Upgrade - - - - - - - - - - - - - - - - - - - - Post #3233
Amplifier - - - - - - - - - - - - - - - - - - - - - - - - - - - - Post #3242
LED Backup Lights - - - - - - - - - - - - - - - - - - - - Post #3266
Hawk Pride - 3-5-2022 - - - - - - - - - - - - - - - - - - Post #3269
New 59 psi Fuel Pump for the Hemi - - - - - - - - Post #3280
Trailer Tongue Weight - - - - - - - - - - - - - - - - - - - Post #3302
Moab 2022 - - - - - - - - - - - - - - - - - - - - - - - - - - Post # 3305
