Howdy all,
I've recently been having some fuel pressure problems with my 95 4.0L YJ. After fixing some other problems with it (including spark and ecu issues) I noticed that my jeep wasn't getting any fuel pressure, I checked the schrader valve and there was no fuel coming out. I couldn't hear my fuel pump priming and decided to buy and install a new fuel pump and that didn't work, or so I thought. I checked my valve again and there was fuel coming out, so I decided to try and start her up. Once I turned the key I noticed that the engine wanted to start, and actually managed to start only for it to die a second or two later. What could my problem be? I was considering that the fuel pump might not be getting enough power and as a result isn't building up enough pressure to supply the engine... I actually have a video of one of my start attempts; however, I'm not allowed to place it on here since I am a new user.
Thanks!
EDIT:
After cleaning the fuel lines, changing the fuel filter, fuel pump and cleaning the injectors I still don't have adequate fuel pressure/any. The fuel pump won't send any fuel through the lines. I am starting to think that it may be a bad sensor somewhere/ wire. I am still open to any second thoughts though and they would be greatly appreciated!
Thanks!
EDIT:
