My jeep right after I got it. Found the rims in Craigslist and put them on that day
Well for starters you could always save that money for an engine upgrade and just do a spring over for starters. My future DD in ny garage will run 33s with a base spring over and a possible 1" body lift. But even going up to a 4.0 HO will show a difference in that jeep. Not to mention you can find decent ones on cl in older cherokees pretty cheap. And keep an eye out for an ax15 trans attached to that 4.0 and go from there. I wouldn't worry much about the lifting before I got all the power I wanyed, and just go basics. Sort the rust, check on a new drive train, upgrade the front and rears with spring over set up already and then worry over lifts.As far as the lift goes. It's the first thing I wanna do. I will have money but not crazy amounts so I'm looking at either the RC 2.5 and maybe a 1 inch body or the RC 4 inch. I'm worried that the 2.5 kit will need (break line extensions potman arm extension and transfer drop kit which it does not come with, but I'm also worried that if I get the 4 inch it will look bad with only 31 tires. And it's my DD so I don't wanna go over 31 and it lose all it's power. Suggestions and comments would be appreciated
I would change the engine. Only problem I have is that everything I do to the jeep has to be done one weekend at a time. It's the only vehicle I have to get to work with. I'm not good enough to do an engine swap in that short amount of timeWell for starters you could always save that money for an engine upgrade and just do a spring over for starters. My future DD in ny garage will run 33s with a base spring over and a possible 1" body lift. But even going up to a 4.0 HO will show a difference in that jeep. Not to mention you can find decent ones on cl in older cherokees pretty cheap. And keep an eye out for an ax15 trans attached to that 4.0 and go from there. I wouldn't worry much about the lifting before I got all the power I wanyed, and just go basics. Sort the rust, check on a new drive train, upgrade the front and rears with spring over set up already and then worry over lifts.
