So after a ton of time debating and researching a 4 link rear, I decided to pull the trigger. In 2 afternoons after work, I was able to strip everything off the frame and axle. Figured I was making quick and solid progress but the tricky part is starting now.
The basic plan is to keep the stock fuel tank but maximize as much wheelbase as I can muster without going off the deepend. If I decide I need more wheelbase later, I'll lengthen the links. I am using Fox 14" coilovers and will be using square links made of 2" x 0.25" wall steel. Most of the brackets came from Barnes4WD and the joints are 1.25 Trailgear Creeper joints.
Things I've already learned so far...
1. I've spent months researching and hours under the Jeep measuring and planning but that's already going out the window.
2. At full bump, there is NO room under the jeep for any parts.
3. Speaking of room... I've got an engine hoist holding up the back of the jeep so I can raise it high enough to roll the axle out and jack stands under the frame for when the engine hoist needs to move to get the axle out of the garage. Then I've got a jack under the trans to hold it up since I need behind the skidplate and a jack stand under the pinion to hold it up. There's no room for me under there either.
4. Consumables are getting consumed at an alarming rate. I've used 4 flap discs, 5 cutoff wheels, and 4 plasma cutter tips already.
5. With a plasma cutter, welder, grinder, cutoff wheel, and a fan for cooling me, the wires are always tangled.
6. The frame angles outboard under the skidplate so even a 20° fitting and maxing out the joint flex will not get my links pointed to the center of the axle so on to plan H at this point...haha
