1 - 3 of 3 Posts
A little back story, sorry, will keep it short:
As a surprise, my wife contacted a Jeep Club to install a 4" Tuff Country EZ Ride Suspension Lift on my 2006 TJ while I was deployed to Iraq. She got the lift from JC Whitney but they sent her the lift for a 2007. This was not caught by the people that installed the lift. The 2007 lift does not come with adjustable control arms, so the ones they installed were not the correct length which led to an incorrect driveshaft angle, among other things. Once I drove it, I realized there was an issue and got it corrected after JC Whitney sent me the correct CA's (control arms). But the guys who installed it said that the lengths in the lift directions did not match the lengths they needed to put the CA's at on my Jeep. Now one of my rear lower CA's has failed and I am in the process of ordering some and was going to install them myself but after reading a lot of the forums on CA's and the issues I had with the initial lift being installed, it made me question if I need to take the Jeep to someone who can check EVERYTHING to make sure the lift is installed correctly. And I am referring to the axles being centered and square to each other and front & rear pinion angles and those sorts of important things. I dont think the local mechanics know the specifics (and neither do I) of what to inspect to make sure all that is correct for this Jeep. So when someone has this issue, where would one take his Jeep to give it their blessing?
Yes you need to take to a competent shop. A 07 is not even the same suspension. The arms are way longer and will not work on a TJ.
also.. Though what your wife wanted to do you something nice, she may have just tossed a wad of cash in a hole. JC has a lot of cool stuff, but lifts for jeeps by the brand you said is not a good one...
Since you home and may want to try installing a good lift yourself, there are some real good ones on here that others will advise you on.
getting everything square is not that hard if you are mechanically inclined. it takes time and patience to do it right but it can be done at home with only a few basic tools. but if you want to bring it to a shop, I can't help much since im not from where you are.
1 - 3 of 3 Posts
