well its also posible the crank sensor is throwing this code... i have had it happen, otherwise you can trace wiring make sure sensor plug is clean and tightly connected and double check the ground on it(not sure of colour atm) (if equipped with both sensors..
also you can clear the code start it up and move wiring around to see if it triggers it faster or not.. but just a thought and watch yo fingers...
also low battery power can trigger this code.. have you load tested battery? under load does it hold voltage?
so many issues can cause this that ive run accross on many vehicles.. up to and including vacuum leaks...
