Mean Green Mean Green High-Output 140amp Alternator [$360]
13860 8
Product Information
Price $360
Rating 4
Average Price $349.57
Manufacturer Mean Green
Recommended Yes: 7 / No: 0
1978-86 CJ with 4 or 6 cylinder engine and 304 V8 engine, 1984-86 XJ Cherokee with 2.5L 4 cylinder engine, Non-serpentine belt drive, For CJ use with 6 cylinder engines. This is a heavy-duty, high output Alternator producing 140 amps. Mean Green's Alternator is the perfect complement for dual batteries. Inside, there's a state-of-the-art voltage regulator designed to protect wiring and ignition systems. Made in the USA; this High Output Alternator has a one year unconditional warranty. If it fails, Mean Green will replace it.
1 - 9 of 9 Posts
Discussion Starter · #2 ·
Price $359
Rating 5
Recommended yes
Comments: Works great with NW Wrangler Dual Battery System filled with Optima Yellow Top batteries! There is no problem running all my accessories even without the second battery because this deep cycle alternator performs!
Price $360
Rating 5
Recommended yes
Comments: great. Powers two Optima yellow tops. --------------------------------------------------------------------------------------------------------------------------------------------------------------------
Price $378
Rating 5
Pros High output (200 amps). Warranty is excellent. Durable as anything I've bolted on my WK.
Cons None
Recommended yes
Comments: Best $378 I've spent. It anchors my audio system, fog lights, interior lights, power inverter.... Would highly recommend.
Recovering Bronco Rider
Price $350
Rating 5
Pros Chrome is deep & rich
Cons Hard to keep clean
Recommended yes
Comments: Keeps both Ultima's charged even during a 16,000 lbs pull @ 1800 rpms from my "set throttle". My barn is solar/battery/inverter powered. W/a feed to my house. I have a huge battery bank in my barn using 29" tall utility Co batts and 15k watts of inverters. I set my throttle @ 1700 rpms & it will power the essentials, and them some, of my whole house. :highfive:
Plus it's a hit jump starting "Soccer Moms" when out "Mall Wheeling"!
1 - 9 of 9 Posts
