1 - 10 of 10 Posts
Hello everyone.
So i was thinking about getting a lift but decided to postpone that.
I'm getting rid of my 17" rims tire size 215/65's for some 16x7" rims.. now my question is.
What's the MAX tire size I can go up to without rub on a 4x4 unlimited MK?
I was thinking general grabbers at2 which is a 235/70R16. I have confirmation that this DOES fit from another user.. but wanted more then one confirmation.
I'm in no way a technical expert on spacers or offset but in my opinion 235 is too fat for a Jeep Patriot because of the limited clearance to the struts. 235/70/16 is about 29" in diameter and if it didn't rub it would be very close to it. I would not go wider than 225.
I have noticed a difference of opinion on the max tire size on the patriot and I'm not sure why. Some people say they run this size tire and/or this wheel, then others will say there's no way that will work...even though there are pictures to show it.
Can anyone please provide more clarity here? I have a 4x2 and I'm also interested in a final answer with regard to the tallest and fattest tire I can fit without a lift.
Thanks
the_jeep_now said:
29'' would be max without a lift. Depending on the rim offset, it might slightly rub on inner wheel well.
I read somewhere that the offset on my stock steel rim is 39mm...but I have no idea quite how to interpret that. I'm assuming you mean get an offset that pushes the wheel out somewhat. What offset would I need to look for?
The Necessary Evil
How to measure offset: https://www.rsracing.com/tech-wheel.html
The MKs have about a +40 mm offset. I say about because the 16, 17 & 18" wheels vary. Keep in mind that 5 mm = 0.2" or not much.
We know that a tread width of 235 fits and in some cases even a 245 will fit. Why do some work and not others"? It relates to the bulge of the sidewall which relates to the width of the rim and the tread width of the tire. Tires are made to cover a certain rim width and have a normal appearing 'bulge' in the sidewall. If you have a fat tire on a skinny rim then you will have a large bulge or more curving out on the sidewall and that may hit on something like the brake line but the bracket for that can be bent to gain some clearance if needed. There is no substitute for a trial fit unless you know that someone has tried your exact combination and said that it works. There are no reasons that the tires sizes that we have listed would not work.
The aspect ratio is not the bulge. I know of no way to calculate it either.
Just a note here. I just dropped down from 235/60R18 to 235/65R16 and I'm getting better actual mpg. maybe 1/2 mpg different.
Thanks
225 65 17 without lift no rub I run them on a 2011 Patriot
1 - 10 of 10 Posts
