Hello fellow YJ AX15ers with the trusty internal slave :|
I've been poking around and have found a lot of threads on my slave and master cylinder and all the problems that I am having. I have not found an answer to this yet.
I replaced my Master and Slave on the internal AX15. I did not however, replace the hose that connects the 2 parts. I am having the common issue of losing my clutch hydraulic pressure about 3 days after I bleed the system. My guess is that the slave I put in is bad. That seems to be the common theme on the forums. When I bleed my system I get dirty brown and chunky fluid coming out. Is it possible that the hose I have is failing me and allowing air into my system while simultaneously falling apart on the inside? It's 100 dollars for a new stainless steel hose from advanced adapters. They also have the conversion kit to the external slave and it's around 5.5X the amount. I am waiting until July to do that. In the meantime, should I switch out that part? Anybody ever switched that part and
had success with the system? Should I just keep bleeding the system every 3 days until July, it's easy enough.
Thanks in advance!
