About six months ago,lol, I bought a bunch of led stuff after reading this thread by cAcHe which was a good one. http://www.jeepforum.com/forum/f197/how-change-dash-light-93-98-zj-767865/ Not wanting to do anything major this weekend I decided I would do this. Pulling the control has been covered elsewhere so right to it. The 93-96 controls are a little different from the 97-98 but its got to be similar. Pull the knobs, and with a flat blade release the two upper and two lower snaps that hold the front cover on. We will be dealing with the three twist in gray sockets at the top and the NEO wedge style black socket to the left lower of the vacumn selector switch. Twist the gray ones out by pushing down and turning or lifting up the locking tangs and turning. The Neo style will twist out with a fine tip flat screw driver inserted in the slot on the back of the socket.
To the upper left of the Neo hole, you'll see a small hole that exposes two soldered pins on the small circuit board inside the control. Those are the ends of the white led for the A/C button. To have enough room to solder it out and in I had to make that hole larger. Tried a heated exacto but it was too slow,and the RS soldering iron came with a bunch of nifty tips so I switched to a pointy one and melted the hole out.
Turn the control over and pull off the A/C button straight up. This exposes the led. I had to make a rig to hold the led down so when I heated the pins I could pull the housing off the pins.
Heat up the iron.
Heat up the iron.
