2001 JGC Limited v8 with 133k miles. Dual zone automatic climate control. The heat works fine on both sides but I have very low air flow coming from the vents. The center-left vent blows air out fine but the center-right vent is weak as well as the driver, passenger, and floor vents. Vents for the defroster produce good air flow. I can adjust the fan level and hear it making more noise but the airflow out of the vents is little to none.
I have taken out the glove box and done a little exploring. Mainly because I wanted to rule out a blend door issue. Turns out the previous owner had the blend doors replaced and I could see where the piece of plastic was cut away. Whoever did the repair job really half blanked it. Broken screw mounts for the blend door motor and such, terrible duct tape job to re-secure the plastic piece that was cutout to access the blend doors. While inspecting this I did notice a lot of airflow coming through is area where the plastic piece was cut away. So i'm linking I'm losing a little airflow there. I re-secured that plastic piece and tried my best to seal up any areas where air could leak out but there was only a marginal improvement in the airflow to the vents.
When I run the diagnostic on the automatic climate control it shows a 20 which has something to do with the recirc door travel. I inspected the recirc door and it was working just fine - opens and closes just fine.
Do you all have any suggestions/ideas as to what else I should check besides taking apart the dash and console to get at that area?
Thanks for the help!
