521 - 540 of 2502 Posts
Discussion Starter · #521 ·
Thanks Fernando.
I got a little done yesterday. I wired in a trailer plug last night to pull a small trailer this evening.
It was actually pretty easy especially when you have a voltmeter.
I also took my jeep to work and used Mean Max's method to aligning the front end.
Rouge Nation!:cheers2:
Ill have to look up that write up myself as Ill be building a trailer soon.
Cant wait to see your jeep with the louver inserts in the fenders
Discussion Starter · #523 ·
I have a hankering for the Hazelnut Brown.
I'm curious to see how it looks too. I'm pretty stoked about it.
Discussion Starter · #524 ·
I drove the jeep about 4-1/2 hours yesterday. I towed a small trailer toting my washer and dryer to my folks house. I didn't want to make a detour there and fool with it when I make the big move so I took care of it now. Well the jeep did OK. The power was there but I couldn't tackle a hill or maintain speed without it overheating. I know my e-fan was on at the low speed the entire time but couldn't keep it cool. I had to turn on the high speed to bring the temp back down. I did this a number of times. If I slowed down and came to a stop it would cool with the low speed. I finally just decided to run my defroster on low the entire time on the way back home. It kept the temperature right below 210.
When I got home I popped the hood and the plastic top of the radiator was very hot but the cap was cold (boiled over to the overflow I think) and the cores on the outside were hot but when I put my hand over the center cores it was cool. I'm thinking my radiator is plugged. Since I have the Autozone lifetime replacement I'm going to call them and tell them what's going on and if they'll swap it out. If not I'll make it leak and swap it in. If the new one does the same thing I'm going to get a better one and just store the A-zone as a backup.
What do y'all think? Oh and a pic of the trailer.
Why not just run the fan on high when it gets hot? Then back to low while its at a good temp? Seems kinda normal while pulling a trailer, unless it dose that when your not towing too?
Sounds bad to me. My new radiator and flushed system works great while I temporarily don't even have a shroud. We hit 109 this week and 103 is our high today. I've been wheeling without a shroud too. (I'll put it on soon)
Discussion Starter · #528 ·
I did flip the high speed on when it overheated and it brought the temp back down but I don't feel like I should have to rely on that. Plus it would overheat on the highway with no trailer. It just took a little longer to overheat. I also think it boiled over and didn't replenish because the radiator cap was not hot. Usually it is.
Yes i would say you have a problem if it does it when not towing as well. Hope you get it figured!
Or, why not just run the fan on high all the time for now if you cant get a new one from Auto Zone
Discussion Starter · #532 ·
That may be an easier option. Autozone said they could have me another in in a day but I need to bring the old one in. I'm pretty sure I can have it out and back in if I get it over there in a day or so.
Discussion Starter · #533 ·
Well I went ahead and took the radiator out. It didn't take too long and I'm hoping I can get it over to Autozone before 12 tomorrow. It looks a little rough so we'll see how it works.
Discussion Starter · #534 ·
I forgot to mention I went to New Smyrna Beach, Florida this past weekend to spend time with the family. They rented a house right off the beach and both my brothers, my sister, and nephew were there. Had a lot of fun. My view.
I swung by Autozone and picked up a new radiator.
My Taurus fan on.
Finished product.
Discussion Starter · #536 ·
Hopefully that will fix the cooling issue.
We can only hope. I looked at my Haynes and it says the 4.0L take 10 quarts of a 50/50 coolant mix. I put a gallon in (4 quarts) so I need to get another gallon. I'll probably do a 70-30 mix ratio.
Discussion Starter · #537 ·
I got the new radiator in and took it for a spin. It cooled great especially on the highway. It would run cooler on the highway and heat up right below 210 at a stop light. After a while I checked the radiator and it was low on coolant and it was still cooling well. I filled it up all the way so I think I'm good to go. The test will be towing.
Discussion Starter · #538 ·
I've been donating and throwing crap away to prepare for the move. While I was tossing away some metal I saw an old exercise bike in the scrap metal bin. Scored an adjustable throttle.
I also remembered that I have some brake cable...win.
Discussion Starter · #540 ·
Where'd ya get those brake cables from?
Some guy who use to BMX decided he didn't need them. :D
By the way, I have an interview at KUB on the 6th.
