Indiana:
Michigan:
Iowa:IN.gov said:Information Maintained by the Office of Code Revision Indiana Legislative Services Agency
06/01/2008 02:45:29 PM EDT
IC 9-19-12
Chapter 12. Rear View Mirrors
IC 9-19-12-1
Safety requirements
Sec. 1. A motor vehicle that is constructed or loaded so as to obstruct the driver's view to the rear from the driver's position must be equipped with a mirror located so as to reflect to the driver a view of the highway for a distance of at least two hundred (200) feet to the rear of the vehicle.
As added by P.L.2-1991, SEC.7.
IC 9-19-12-2
United States Department of Transportation regulations; classification of violations
Sec. 2. (a) This section does not apply to a person who owns or operates a vehicle or combination of vehicles that:
(1) contain parts and accessories; and
(2) is equipped;
as required under regulations of the United States Department of Transportation.
(b) A person who violates this chapter commits a Class C infraction.
Kansas:nextsearch.legis.state.ia.us said:321.437 Mirrors .
1. Every motor vehicle shall be equipped with a mirror so located as to reflect to the driver a view of the highway for a distance of at least two hundred feet to the rear of such vehicle. Any motor vehicle so loaded, or towing another vehicle in such manner, as to obstruct the view in a rear view mirror located in the driver's compartment shall be equipped with a side mirror so located that the view to the rear will not be obstructed however when such vehicle is not loaded or towing another vehicle the side mirrors shall be retracted or removed. All van or van type motor vehicles shall be equipped with outside mirrors of unit magnification, each with not less than nineteen point five square inches of reflective surface, installed with stable supports on both sides of the vehicle, located so as to provide the driver a view to the rear along both sides of the vehicle, and adjustable in both the horizontal and vertical directions to view the rearward scene.
2. Notwithstanding this chapter or chapter 321E , a combination of vehicles coupled together which is used exclusively for the transportation of passenger vehicles, light delivery trucks, panel delivery trucks, pickups, boats, and recreational chassis, may permanently attach a convex-type mirror on either or both of the vertical supports, forward of the steering axle of the power unit, provided that the mirror shall not extend beyond the limit of any other rearview mirror on the vehicle.
[C31, 35, §5105-c20; C39, § 5034.46; C46, 50, 54, 58, 62, 66, 71, 73, 75, 77, 79, 81, §321.437]
86 Acts, ch 1210, §5
For applicable scheduled fines, see § 805.8A , subsection 3, paragraph b, and subsection 12, paragraph b
Kentucky:www.kslegislature.org/legsrv-statutes/ said:Chapter 8.--AUTOMOBILES AND OTHER VEHICLES
Article 17.--UNIFORM ACT REGULATING TRAFFIC; EQUIPMENT OF VEHICLES
8-1740. Mirrors. (a) After January 1, 1975, every motor vehicle shall be equipped with a mirror mounted on the left side of the vehicle and so located as to reflect to the driver a view of the highway to the rear of the vehicle.
(b) Every motor vehicle, except a motorcycle, shall be equipped with an additional mirror mounted either inside the vehicle approximately in the center or outside the vehicle on the right side and so located as to reflect to the driver a view of the highway to the rear of the vehicle.
(c) All mirrors required by regulations of the United States department of transportation shall be maintained in good condition.
Louisiana:louisvillelaw.com said:189.130 Mirrors.
(1) Except as provided in subsection (4) of this section, every motor vehicle shall be
equipped with the following mirrors so located and adjusted as to reflect to the
driver a view of the highway to the rear of the vehicle:
(a) One (1) mirror mounted on the left side of the vehicle; and
(b) One (1) mirror mounted either inside the vehicle approximately in the center
or on the right side of the vehicle.
(2) No person shall, by himself or through his agent or servant, operate a motor vehicle
upon the highways without the equipment required by subsection (1). Each day of
operation without the equipment shall constitute a separate offense.
(3) No person shall sell, barter, or otherwise dispose of any motor vehicle described in
subsection (1) unless it is equipped with a mirror as provided in that subsection.
(4) A motorcycle shall be required only to have the mirror identified a paragraph (a) of
subsection (1) of this section.
Effective: July 12, 2006
History: Amended 2006 Ky. Acts ch. 173, sec. 9, effective July 12, 2006. -- Recodified
1942 Ky. Acts ch. 208, sec. 1, effective October 1, 1942, from Ky. Stat. secs. 2739g-
69a, 2739i-1 to 2739i-3.
Maine:legis.state.la.us said:§354. Mirrors
A. After January 1, 1975, every motor vehicle manufactured or assembled after December 31, 1972, of a type subject to registration in this state shall be equipped with a mirror mounted on the left side of the vehicle and so located as to reflect to the driver a view of the highway for a distance of at least two hundred feet to the rear of the vehicle.
B. Every motor vehicle of a type subject to registration in this state, except a motorcycle or motor driven cycle, shall be equipped with an additional mirror mounted either inside the vehicle approximately in the center or outside the vehicle on the right side and so located as to reflect to the driver a view of the highway for a distance of at least two hundred feet to the rear of the vehicle. When the required view from the inside mirror is obstructed, an outside mirror on the right side of the vehicle shall be required.
C. All mirrors required by this section shall be maintained in good condition at all times.
D. In addition to the mirrors required in Subsections A and B of this Section, every school bus shall be equipped with a mirror on the right side of the vehicle and so located as to reflect to the driver a view of the highway for a distance of at least two hundred feet to the rear of the vehicle.
E. Every school bus shall be equipped with a mirror of a type and so located as to give the seated driver a view of the area immediately in front of the front bumper, provided, however, that any Type II school bus constructed in such a way that the seated driver has a view of the area immediately in front of the front bumper need not be equipped with the mirror otherwise required by this Subsection.
F. Notwithstanding any provision of this Section or any other provision of law to the contrary, motor vehicles which are used by rural mail carriers in the performance of their duties shall not be required to be equipped with a mirror on the passenger side of the vehicle.
G. In addition to the mirrors required in Subsections A and B of this Section, every delivery van which is part of an official state motor vehicle fleet shall be equipped with a mirror of a type and so located as to give the seated driver a view of the area immediately in the rear of the rear bumper.
Acts 1962, No. 310, §1. Amended by Acts 1968, No. 273, §4; Acts 1974, No. 21, §1; Acts 1976, No. 383, §1; Acts 1993, No. 97, §1; Acts 1997, No. 187, §1.
Maryland:janus.state.me.us said:§1914
Title 29-A: MOTOR VEHICLES HEADING: PL 1993, c. 683, Pt. A, §2 (new); Pt. B, §5 (aff)
Chapter 17: EQUIPMENT HEADING: PL 1993, c. 683, Pt. A, §2 (new); Pt. B, §5 (aff)
Subchapter 1: GENERAL PROVISIONS HEADING: PL 1993, c. 683, Pt. A, §2 (new); Pt. B, §5 (aff)
§1913. Mirrors
1. Mirrors required. A person may not operate on a public way a vehicle so constructed, equipped, loaded or used that the operator is prevented from having a constantly free and unobstructed view of the way immediately to the rear, unless there is attached a mirror or reflector placed and adjusted to afford the operator a clear, reflected view of the highway to the rear of the vehicle for a distance of at least 200 feet.
[ 1993, c. 683, Pt. A, §2 (NEW); 1993, c. 683, Pt. B, §5 (AFF) .]
2. Temporary mirrors. When a vehicle is operated without a trailer or semitrailer, temporary outside rearview mirrors must be removed or otherwise adjusted so as not to extend beyond the width of the automobile.
3. Motorcycles. A motorcycle must be equipped with a rear view mirror mounted and adjusted to afford the operator a clear, reflected view of the highway in the rear for a distance of at least 200 feet.
[ 2005, c. 577, §26 (AMD) .]
SECTION HISTORY
1993, c. 683, §A2 (NEW). 1993, c. 683, §B5 (AFF). 2005, c. 577, §26 (AMD).
Massachusetts:michie.com/marland said:§ 22-403. Mirrors.
(a) Motor vehicles - In general.- Every motor vehicle shall be equipped with at least one mirror located to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of the vehicle.
(b) Same - Registered in this State.- Every motor vehicle registered in this State shall be equipped with an outside mirror on the driver's side located to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of the vehicle and along the driver's side of the vehicle. This subsection does not apply to motorcycles, which are governed by subsection (c) of this section.
(c) Motorcycle.- Every motorcycle shall be equipped with two rearview mirrors, one each attached to the right and left handlebars, which shall meet applicable federal motor vehicle safety standards.
(d) Obstruction of inside view.- Where the view through the inside rearview mirror is obstructed, two outside rearview mirrors are required.
[An. Code 1957, art. 661/2, § 12-403; 1977, ch. 14, § 2; 1999, ch. 645.]
Mass. lawmakers need to investigate the use of paragraphs!mass.gov/legis/laws/mgl/90-7.htm said:.....Every motor vehicle shall be equipped with at least one mirror so placed and adjusted as to afford the operator a clear, reflected view of the highway to the rear and left side of the vehicle.....
Michigan:
Minnesota:legislature.mi.gov said:MICHIGAN VEHICLE CODE (EXCERPT)
Act 300 of 1949
257.708 Mirrors.
Sec. 708.
A person shall not drive a motor vehicle on a highway which is so constructed or loaded as to prevent the driver from obtaining a view of the highway to the rear by looking backward from the driver's position, unless the vehicle is equipped with a mirror located so as to reflect to the driver a view of the highway to the rear of the vehicle. In addition all motor vehicles shall be equipped with an outside rearview mirror on the driver's side which shall be positioned to give the driver a rearviewing angle from the driver's side of the vehicle, except a motor vehicle licensed as an historic vehicle if the vehicle was not originally equipped with an outside rearview mirror. Rearview mirrors may be positioned on the helmet or visor worn by the operator of a motorcycle if the helmet is securely attached to the head of the operator. Every commercial vehicle of 1/2 ton capacity or more, operating upon the public highways of this state, shall be equipped with 2 mirrors, 1 on each side, adjusted so that the operator shall have a clear view of the highway behind the commercial vehicle. The outside mirrors shall not be considered to be a part of the vehicle for the purpose of determining the maximum width under section 717.
History: 1949, Act 300, Eff. Sept. 23, 1949 ;-- Am. 1967, Act 90, Eff. Jan. 1, 1968 ;-- Am. 1970, Act 94, Imd. Eff. July 20, 1970 ;-- Am. 1978, Act 55, Imd. Eff. Mar. 10, 1978
© 2007 Legislative Council, State of Michigan
Mississippi:revisor.leg.state.mn.us said:169.70 REAR VIEW MIRROR.
Every motor vehicle which is so constructed, loaded or connected with another vehicle as
to obstruct the driver's view to the rear thereof from the driver's position shall be equipped with
200 feet to the rear of such vehicle.
History: (2720-259) 1937 c 464 s 109
Missouri:michie.com/mississippi said:§ 63-7-57. Mirrors.
Every motor vehicle which is so constructed or loaded as to obstruct the driver's view to the rear thereof from the driver's position shall be equipped with a mirror so located as to reflect to the driver a view of the highway for a distance of at least two hundred feet to the rear of such vehicle.
Sources: Codes, 1942, § 8252; Laws, 1938, ch. 200.
moga.mo.gov said:section 307-107
4. Mirrors: All motor vehicles which are so constructed or loaded that the operator cannot see the road behind such vehicle by looking back or around the side of such vehicle shall be equipped with a mirror so adjusted as to reveal the road behind and be visible from the operator's seat.
