hi guys, i need your help in this liberty kj renegade 2003, what lift size i need, i have rubicon 255 75 17 tires, i want to put them on help, can it be done? thanks
That tire is likely 3" greater in diameter than stock. A lick helps only with rubbing the top of the wheel well. The larger tires are likely to rub front or rear and inhibit your turning circle without adding hub spaces (which I detest).
The smarter move for a Libby is a lift kit and NOT changing the tire diameter. I did that on my 2008 KK and then again on my 2011 KK. VEry please withthe results. I did this for function, not for looks.
