Cards81fan said:I vote
E: Don't mess with it because it's rated for 100,000 miles (whatever that means) or some other obnoxious length of time, and IIRS it's inside your fuel tank with the fuel pump and is a PAIN to mess with.
Some have even said that it's a "Lifetime" filter, but whose lifetime? Mine, the Jeep's, or the Filter's?![]()
The gas filter is not inside the gas tank.lightfoot1976 said:now why would they put a fuel filter in the gas tank???? is that dumb or what? I can't believe that there is ANY filter that's got a lifetime shelf life. I do believe in the "if it ain't broke, don't fix it " maxim. And i certainly don't plan on changing it anytime in the future.
Cheaper on-line @ $104.14. Not much savings though for a fuel filter.lightfoot1976 said:This is the only vehicle I've ever owned where I couldn't easily replace the fuel filter every 30,000 miles. If the cost for the dealership is $130 then I'm not changing it for one hell of a long time.
I don't believe ANY filter is good for the lifetime of a vehicle. It just makes sense to change the fuel filter at least every 30,000 miles, but who's going to do that when its so damned expensive to change a simple thing like that. It should be accessible from under the hood and easy to change like most other fuel filters.Long Island KJ said:I just went through 2 fuel pumps on my 03 Caravan with only 21000 miles on the clock. After the second pump fried the dealer told me it was a dirty fuel filter causing it to burn,so they got me for $80 to change the filter ( part only ) the rest was warranty.
My conclusion is... ok dirty filter causes resistance on the pump and eventually fries it, or the first pump was a bad one and they just wanted to get me to buy a new filter.
I hope it was a bad pump because if these fuel filters need to be replaced every 10 or 15,000 miles to keep the pump from failing, I'll sell my Liberty as soon as the first pump goes,
My 01 Outback is like that. The tranny has a drain plug and an external screw on filter. Brilliant.FYI, my wifes '02 Mitsubishi Montero has a "non-serviceable" fuel filter. Dealer said don't worry about it. Have 120K on it now and it runs flawlessly. It also has a "non serv" trans filter/screen. Changing fluids is a dream. Everything has a drain plug, trans, diffs, transfer case. I wish they still sold them here.
