Nice rig. Where are you in those pictures? I don’t recall seeing that many palm trees in Charlotte...
We moved to South Florida back in 2017 for my job. Not the biggest fan of it here but money is nice and so is the weather! This will be my semi DD, along side my M6 GC and weekend cruiser with the family. Once we get back north, it'll take on the next stepNice rig. Where are you in those pictures? I don't recall seeing that many palm trees in Charlotte...
It is copper brown metallic off of a 81 AMC CJ color chart.Any more pictures of this jeep. I love that color. What color is it?
That looks great. I love the copper brown colors. I saw a late model Corvette a few years back that had just about the perfect copper orange color. If I ever have the need to re-paint my Rubihara I would really consider that color. Great to see your kid helping out. My kids don't take that much interest.It is copper brown metallic off of a 81 AMC CJ color chart.
This is the future driver of this LJ. From tacking in steel to wiping filler he has helped with every step of the project.
Looks sharp for 226k!Back in an LJR. Feels amazing to drive this slow, clanky, simple but absolutely fabulous vehicle! After 6 hours of detailing/polishing/coating, you'd never know she has 226k on her! Have a bunch of parts for it, black magic brakes, lines, calipers, cats, exhaust, Savvy/Currie lift and Geolander MTs.
Man good eye! I hadn't even noticed until the other day. I have a spare which is the same as the others so I'll use that and use this as a spare. It's definitely cleaner than the others so the PO must have needed a replacement, probably a knock offLooks sharp for 226k!
I picked mine up back in January with 176k and looks decent but not quite that good! I need to do a good detail, and I plan to replace the hood because it has a dent and typical spyder cracking in the factory clear coat but it should be good after that.
Also, don't know if you realize it, but your back passenger wheel is a different MOAB wheel than the other 3. One of my spares is the same as your other 3, and my other 4 are the same as your passenger rear.
I'll be pulling the tire and selling it eventually to have a matched set if your interested in swapping it for one that matches the other 3.
I think that style wheel is from the 2006's. The extra 'rib' on it came out around '05/06. I remember my friend had a new Rubicon back in 06 and it had that style from the factory.Man good eye! I hadn't even noticed until the other day. I have a spare which is the same as the others so I'll use that and use this as a spare. It's definitely cleaner than the others so the PO must have needed a replacement, probably a knock off
Well all my wheels are like the front passenger, in that pic. On the passenger rear is smooth like that. And it's cleaner so I'm assuming the PO replaced it at some pointI think that style wheel is from the 2006's. The extra 'rib' on it came out around '05/06. I remember my friend had a new Rubicon back in 06 and it had that style from the factory.
Mine feels that way and I've done a lot of maintenance, including plugs, cats, full exhaust etc... may do a carbon cleaning next. We both have quite a lot of miles. Time to regear for you as well as myself. Deeper gears will help.Yeah thats likely the case, the wheels with the lip were probably 2005 and 2006 with the smooth ones being 2003-2004.
Does anyone else with a 6spd LJ have an issue with your Jeep feeling slower than normal or low on power from what it should be?
Mine idles fine, seems like it has all the power it should at low RPMs but once you get on it at like 2200 or above it feels like it hits a wall powerwise and doesnt accelerate like it should. If I stomp it at that rpm it starts to go and feels like you let off half way around 2500 rpm and climbs at that slower rate from there on...
Trying to accelerate in 4th at 3k rpm I can have it at the floor for what seems like forever before it finally gets to 4k rpm and just doesn't move like I think it should, its almost hard to accelerate to merge on the highway and thats trying to run it as high as I can in each gear.
Almost feels like my 02 TJ 5spd on 4.56's, 35's, heavy armor and bumpers and hard top accelerates better than my stock 6spd LJ Rubi on 285s...
Yeah I had a parts jeep I swapped the cats because one on my jeep did blow out and I thought it made a difference at first but it may have been placebo because it felt sluggish again a few days later.Mine feels that way and I've done a lot of maintenance, including plugs, cats, full exhaust etc... may do a carbon cleaning next. We both have quite a lot of miles. Time to regear for you as well as myself. Deeper gears will help.
Savvy lift done, on the alignment rack now getting everything dialed in
What size lift are you running? What's the load rating on those tires?The build is coming around. 315/75 Geolander MTs installed. Pretty cool story with Yokohama.. growing up in Jeeps, my dad has a set of Geolanders on his ZJ Grand Cherokee, back 2001! To incorporate them into my build now is pretty awesome.
And three years later, I traded the JKU for a new Touareg for the wife and brought this home today.Here's probably the last shot of my LJ , in the driveway with its replacement.
Tank '15 JKU Willys
More room with the arrival of our second daughter two weeks ago.
Savvy 4", load range E. Most 16" tires will be. I've never had an issue when they're filled to correct psiWhat size lift are you running? What's the load rating on those tires?
Great looking Jeep!!
