what top is that first one?pennieslj said:
Bestop Safari..Jch. said:what top is that first one?
I am running a mix n match 4" short arm and 1" BL. I have a Clayton LA upgrade on order right now that will be going on in a month or two.Dr. Marneaus said:what lift tire combo are you running
:nono:XRussoX said:Unlimited NEED 37s at least... 33s just look too small
Russo
best LJ ever. hands down.33'sUnlimited said:
If you are referring to mine I must actually need 40's since the pic is with 35's right now. Not 33's. Thanks for the advice. :teehee:XRussoX said:Unlimited NEED 37s at least... 33s just look too small
Russo
Thanks Marn. The compliment is much appreciated.Dr. Marneaus said:best LJ ever. hands down.
Thanks for posting.sycotik said:Here is mine. I have some ACOS to level the front out whenever I get home.
They're holding up great. Couple scratches in the clear coat from being in the nasty stuff. No more damage than would happen to the stock rims.Fargo said:By the way. 33Unlimited how is the paint holding up on the Ravines?
