21 - 40 of 50 Posts
Discussion Starter · #25 ·
Whether it's a one night adventure or a weekend excursion,
let CCOR light up the trails!!!
LEDs of all types and configurations!!!
PM or call us with your needs....
706-559-9609​
Discussion Starter · #33 ·
Rough Country Black series
Command the Dark: Stay out later on the trails with Rough Country's sleek 30-inch Single Row CREE LED Light Bar. These sleek, slim-line single-row light bars offer enormous lighting power in a stylish, modern frame. Includes a set of end mounts and adjustable base mounts, providing you with multiple options to mount your light wherever you need to with full adjustability. With a powerful 12,000 Lumens and 150 Watt output, this LED light is a sight to behold.
The black panel design offers jaw-dropping good looks that blend perfectly with any vehicle using black accents like grilles, wheels, bull bars or steps! These all-weather lights feature a durable, die-cast aluminum housing and include a premium, waterproof, flat-wound, braided wiring harness with toggle switch and in-line fuse.
This product includes Rough Country's Light Bar Noise Silencers to quickly eliminate hum, whistle, and other wind noises associated with mounted LED Light bars. These handy Noise Silencers snap over the cooling fins firmly, preventing any noise-generating vibrations and ensuring a snug fit that stays in place. Includes a snap on cover and Rough Country's 3-year Warranty.
FEATURES
12000 lumens
150 watts
Contains 30, 5 watt High Intensity CREE LEDs
30 degree spot beam
IP67 Waterproof rating
Black panel design
Durable die cast aluminum housing
Moisture Breather technology reduces moisture build-up behind the lends
Noise Silencers eliminate hum, whistle, and other wind noises associated with mounted LED Light bars
Includes premium, flat-wound wiring harness with on/off switch
Includes a snap-on cover
Features both end mounts and adjustable base mounts for multiple mounting solutions
Length: 31.37-inches | Depth: 3.12-inches | Height: 1.6-inches
Bolt Diameter: 8mm
3 year warranty
706-559-9609
Discussion Starter · #35 ·
706-559-9609
Discussion Starter · #37 ·
Wanna light up like Rudolph's nose?
Look no further than CCOR.
We have all the lighting you need for your rig.
From headlights to light bars to halos we have it all.
Pm, Post or give us a call @ 706-559-9609
Discussion Starter · #39 ·
FEATURES
12000 lumens
150 watts
30 degree spot beam
Black panel design
Bolt Diameter: 8mm
3 year warranty
706-559-9609
Discussion Starter · #40 ·
706-559-9609
21 - 40 of 50 Posts
