Product Information
Four generations of research, revisions, and resilience - and now the one that started it all emerges as wicked as ever.
The legendary Solo-Baric L7 Subwoofer maintains the throne as the first and foremost authority on bass. Square? You bet! KICKER wrote the book on it, and then patented it. Solo-Baric is the only patented square subwoofer on Earth - more cone, more air, more decibels!
Available in punishing 8-, 10-, 12-, and 15-inch models, the Solo-Baric L7 utilizes the one-piece, injection-molded SoloKon™, a reinforced cone that provides 16 to 20 percent more area than a same-sized cone on a round sub. The Solo-Baric's expansive cone area moves more air than the round one, therefore making it louder.
KICKER's knack for extraordinary bass is evident. The L7 motor structure contains dual high-temp voice coils, a poly-cotton semi-progressive spider (two in the colossal S15L7!), jacketed braided tinsel leads, highly-efficient UniPlate™ pole piece/back plate, and a heat-reducing T-cut top plate for outstanding toughness and enormous power handling. The cast aluminum basket yields a super-sealing, rear foam gasket and spring-loaded terminals. A shielding front gasket helps to protect the wide Santoprene® surround.
The Solo-Baric L7 is available in 2-Ohm or 4-Ohm DVC and hammers in a sealed or vented box application.
http://www.kicker.com/06/tech-support/manuals/manuals/2006/2006%20L7%20Sub%20b01%20WEB.pdf
Price | $450 |
Rating | 4 |
Average Price | $257.19 |
Manufacturer | Kicker |
Recommended | Yes: 17 / No: 1 |
