I will say that I hate, or should I say HATE noisy choppy assed tires. A lot of tires that are really good offroad can become these suckers easily. If you drive them on the road, rotate, rotate, rotate and pay close attention to your tire wear and if the treads are becoming choppy or feathered. Especially the front tires. Tiny little alignment issues cause bad tire wear, especially on these aggressive tires. Some brands tend to be more susceptible to it that others. Anyways, I have seen some BFGs in the shop that scare the hell out of me. I am not really decided yet if they are a good tire or not.
RANT On: Related but slightly off topic but not really.
Tape measure alignments can work and can be accurate. It is in the beholder of the tape and knowing what all the variables are or can be. I do tape and eyeball stuff all the time in the shop when doing steering and suspension work so when I get to the alignment machine I am close. It has to do with runout procedures and aligners for instance do not like caster sweeps or initial camber adjustments if you pull onto it with the toe in a mile off for instance. I know from doing this over and over how bad tape measure alignments can be and how damn close that they can be.
Aligners are more accurate for sure, but always trust your eyeballs if you understand alignment angles. It will clue you in on any method that you used that did not go right. Any method of aligning a vehicle can go terribly wrong, or at least enough to trash a pretty good chunk of coin that you spent on tires in short order.
Speaking from experience.
RANT OFF:
