Trim
The Gladiator is available in base Sport, mid-level Sport S, luxury Overland, and off-road ready Rubicon.
The all-new four-door, five-passenger midsize Gladiator features exterior and interior styling cues from the Wrangler JL.
Four different roof options are available, similar to those on the Wrangler JL, including a black vinyl Sun-Rider soft top and a premium black fabric Sun-Rider soft top (both of which can be fully retracted), a black Freedom-Top three-piece hard top, and a color-keyed Freedom-Top three-piece hard top, both of which have removable aluminum roof panels. The Gladiator is the only convertible pickup truck on the market.
Features
Unique features on the Gladiator include a flat rear load floor for carrying of longer and taller items inside the truck's interior, secure and lockable storage underneath the rear bench seat, and a removable Bluetooth wireless speaker that charges when the vehicle is running, and the speaker is in its docking station located behind the rear bench seat. The Gladiator also offers an optional 8.4-inch touchscreen on the Uconnect 4C NAV. The Gladiator has most safety features that are also in the Wrangler JL including forward-collision warning with active braking and adaptive cruise control.
Capacities
Payload for the Gladiator is 1,600 lb (730 kg).
The standard Gladiator will feature a towing capacity of 7,000 lb (3,200 kg), though a heavy-duty towing package will be available on select Gladiator models that increases the towing capacity to 7,650 lb (3,470 kg).
Powertrain
At launch, the only engine option for the Gladiator will be the 3.6L Pentastar V6 gasoline engine with Variable Valve Timing (VVT) and an Electronic Stop-Start System (ESS), and like the Wrangler JL, will produce 280 horsepower. However, a 3.0L EcoDiesel Turbocharged V6 diesel engine will become available in 2020. Both engines will be mated to either a six-speed manual transmission, or the Wrangler JL's ZF 850RE eight-speed automatic transmission. All Gladiator models will be four-wheel drive.
Offroad
The Gladiator features an approach angle of 43.6 degrees, a breakover angle of 20.3 degrees and a departure angle of 26 degrees. Every one is equiped with heavy-duty Dana® 44 front and rear axles along with a proven 4x4 system offering both high and low ranges.
The Gladiator has front and rear doors that can be fully removed, as well as a windshield that can be lowered (like the Wrangler JL, Jeep includes a tool kit with the tools necessary to remove the doors and lower the windshield). The Gladiator is the only pickup with removable doors.
Gladiator Rubicon adds impressive off-road gear like lockable wide track axles, an electronic disconnecting front sway bar, FOX shocks, 33' all-terrain tires and a forward facing off-road TrailCam® that aids in obstacle navigation.
