The summer after I graduated I got 4 KC 35 series lights for the roof and 2 KC 26 series fog lights for my brush guard. The fog lights were pretty straight forward and also liked how they came with 3 pairs of different lenses (2 amber, 4 clear), but wanted to make sure my roof lights wouldn't leak water inside and it took me about a week to figure it out. I did not drill any holes in the roof or anywhere that could leak water which was a concern of mine when I installed them. It hasn't leaked anywhere at all even when it's gone through an automatic carwash. (Note: I have pics of the driver's side but it is exactly the same idea for the passenger side)
Here's where the wires go over and under the gutter:
With the door open, I used black silicone to keep the wires in place and it's right where there is a gap above where the door meets the door seal. Then down through the hollow part of the weatherstripping:
The hole I ran the wires through into the fender from the weather stipping. The hole was pre-existing:
The wires coming from inside the fender. I drilled two (I believe) 3/8" holes and put a rubber grommet in them:
The holes I drilled through the driver side fire wall. One for my fog lights, and one for both pairs of roof lights all with rubber grommets:
My lazy, but reliable way to run the power for the lights and switches. The wiring harnesses that came with the lights already had a relay and fuses as a part of it so I didn't need to add my own:
Where I mounted my switches. The fog light switch is on the left side, and the two for my roof lights are right above my CB:
When you take off the kick panel there is some sheet metal that I had to cut a notch out of to fit the wires and switches. (Note: these pictures were taken recently as I added the CB a couple months ago and have had the lights up since about winter 2008)
This pic is from when I had first installed them:
A more recent pic with all of the lights on and with clear lenses in the fogs instead of the amber:
