While I admit this is a way to join two wires, IMHO, not the best or even good.
It's an adequate way that doesn't need a high level of skill For this to be 'good' it has to be gas impermeable which it is not.
Ah, now that you can't say with absolute certainty without know the quality of both the crimp, the crimp machine, and the crimper. If not, it will be subject to oxidation, high resistance, and eventual failure.
This idea is strange to me.
Whilst I've done a lot of work on old nails, I can't recall any oxidation related problems with decently made crimps.
Now and then failures from amateur made crimps.
Occasionally I've seen battery terminals damaged by acid fumes from geriatric batteries.
I live in a rust belt.
Soldering is the only way to make a good connection that you can rely on. There are NASA docs that describe the proper soldering techniques. Am not saying to use extreme techniques, just good basic soldering approaches. Easy way outs raise their ugly head later. My background is electronic engineering and, on the repair side of thing, been troubleshooting damn near every type of electronic gadget. I have experienced more than my share of failed crimp connections and bad (cold) solder joints to reinforce proper techniques. New, old, makes no difference-do it right.
There are knowledgeable folks who disagree with you 3.
Crimping offers stronger, more reliable connections than soldering. Soldering uses heated metal to join the cable to the connector. Over time, this filler metal will degrade, which may cause the connection to fail. Most electricians will agree that crimping is also easier than soldering.25 Jun 2019
Crimping vs Soldering Cable Connectors: Which Is Best?
What is a major advantage of the crimped terminal over the soldered terminal?
Crimped connections
create an air-tight seal between the connector and the cable, resulting in long-lasting, reliable connections that are protected from environmental conditions such as moisture, sand, dust, and dirt.
Soldering Vs. Crimping: Advantages & Disadvantages
Why do we crimp wires?
Crimping is a common method for compressing a terminal to a wire conductor without the use of soldering. When done correctly, a crimp
creates a mechanically sound connection that resists corrosion, gas, and liquids.21 Jan 2020
How to Crimp Wires - Company Info
Solderless Makes Sense
We tend to think of soldered joints as the king of electrical connections. Something about the act of heating up a joint and flowing molten solder into it lends a feeling of permanence and quality to the finished product. And soldering was basically the only show in town for the early days of the commercial electronics industry.
But soldered joints have their problems, both electromechanically and in terms of production – after all, an assembly worker can only sling solder around so fast. In the early 1950s, AMP Corporation came out with the first crimp connections for production use, the F-Crimp or open-barrel design. Using this crimping design, AMP sold a wide range of connectors that could be rapidly and repeatably applied to conductors, and that lent themselves to automated fabrication methods in a way that soldering would never be able to achieve.
I had a friend who was an electronics assembly tech for a big defense contractor. He was a production floor guy who had a chip on his shoulder for the engineers with their fancy book-learnin’…
hackaday.com
From my position over the axis of the discussion, it's easier, quicker, and cheaper for an shade tree mechy to make an adequate crimped joint than it is for him to make an adequate soldered joint.
I spent some time as part of a team of three training folks to solder in a workshop set out for the purpose.
Only about 10% of the students, mastered the skill.
Soldering is a high skill, as you admit, you've had your share of failed soldered joints and crimp joints.
Which leads us to believe that neither method is 100%.
I put it to you that crimping and soldering are about as effective as each other when done by trained people.
That crimping is another at least equally effective way to join wires.
And that crimping is easier, quicker, and better in semi-skilled hands.
The kit for which cost a lot less than my soldering iron.
A bit of adhesive shrink-fit over the joint will keep air / fumes away from either sort of joint as effectively as the original insulation.
By your own admission, crimped joints and soldered joints fail, so why only knock crimped joints?
Especially when there's loads of crimped joints around a WJ.
When you have trouble with a ground, do you solder the wire to the ground?
Or do you, like most of us, clean the interface between crimped connector, and bolt it back together, and then drive off?
