My Girlfriend has a 2002 4x4 with the 3.7. She has had it parked in the garage since 2014 not running. A pervious boyfriend had changed the plugs and it quit a couple days after.
The Jeep currently starts but wont idle long then dies if the throttle is opened and rpm's are up to 1200 to 2000 it runs with a slight hickup every couple seconds.
So far I have done the following.
Installed a different battery that tests good
Drained the fuel
Changed the oil
Changed the air filter
Drained and filled the coolant
Put some 91 octane in along with a bottle of Heet
Resealed the plastic manifold "I could hear a leak from there"
Changed all the sparkplugs because I dont think they have ever been actually changed
Replaced all the Coils
Cleaned the TB and replaced the IAC
Fixed vacuum leaks from old cracked hoses
Replaced the Cam position sensor but the new Duralast one seems to not work at all I might exchanged for a different one tonight.
Right now I have no codes
The MAP sensor indicates 12.3 at idle and 8.0 at 2k. We are at about 4k altitude and it reads 13.0 when off.
I have tried to cap the three vacuum lines from the manifold and TB.
The TPS indicates 13% at idle and 75% at WOT
Thinking maybe the Crank Position sensor next. Any ideas?
Derrick
