1 - 6 of 6 Posts
Hello, I've been rebuilding my front axle recently. Installed new yukon gears and new set of bearings.
Since it's the first axle and first ring and pinion I've ever done I wanted to check with someone else my contact pattern.
For me it looks pretty much in the centre between flank and face (what is most important according to installation manual) but maybe I'm missing something here?
Gear Automotive tire Automotive wheel system Machine Auto part
Tire Wheel Automotive tire Motor vehicle Tread
Automotive tire Hood Motor vehicle Bumper Gear
Hood Automotive tire Automotive lighting Bumper Fender
If that were mine I would be OK with both sides, coast and power. How's the back lash and did you use the torque on the pinion to determine the amount of crush.
I get the backlash reading of 0.13-0.14mm (~0.0055") which is on the lower end of the specs (0.12-0.20mm 0.005"-0.008") for dana 30 186. The preload of the pinion I get with seal installed is 18 inch lbs.
Nice job, you did great. Getting the shims for the carrier just right is not fun either. I hope you had a spreader to help you get them in. Again, well done!
thanks! actually I had no spreader tool but reused the original shims that was in the axle. Those shims were pretty thick, being 3mm and more. So I had no problem tapping them with something in.
Getting out the carrier was pretty hard thought...
1 - 6 of 6 Posts
