1 - 20 of 24 Posts
Product Information
Price $400
Rating 4
Average Price $931.3
Manufacturer Jeep
Recommended Yes: 21 / No: 2
The NV242 provides full time 2-wheel, or 4-wheel drive operation. A differential in the transfer case is used to control torque transfer to the front and rear axles. A low range gear provides increased low speed torque capability for off road operation. The low range provides a 2.72:1 reduction ratio
The 2WD and 4x4 full time ranges can be used at any time and on any road surface. The 4x4 part-time and 4 Lo ranges are for off road use only. The only time these ranges can be used on hard surface roads, is when the surface is covered with snow and ice.
Discussion Starter · #2 ·
Rating 5
Recommended yes
Comments: Great Tcase, my linkage lever is a bit out of line but still works well. Switching between 4FT and 2wd is seamless, and can be done at highway speeds
Rating 4
Recommended yes
Comments: Stock transfer case, nothing special here.......................................................................
Price $400
Rating 5
Recommended yes
Comments: [No message]
Price $300
Rating 4
Recommended yes
Comments: It is the stock 242 select trac but that is what was in it and I like the selection that I have with it. Needed replacing.
Price $400
Pros Can switch gears on the fly
Cons Got stuck in 4WD part time once
Recommended yes
Comments: This is a great transfer case. The only problem i had with it was it got stuck in 4WD part time once but it got fixed on its own.
Price $1
Pros Selec-Trac
Cons Finicky about sifting out of 4 sometimes
Recommended yes
Comments: Gets the job done. Won't be changing it out anytime soon.
Price $600
Pros One of the best Jeep transfer cases out there. Offers the following modes:
2 Wheel High
4 Wheel Part Time
4 Wheel Full Time
4 Wheel Lo
Cons None
Recommended yes
Comments: An outstanding combination with this t/c would be quadra-drive axles for better capability offroad in a stock-type configuration.
Price $250
Pros always in 4wd, reliable, hardworking
Cons no 2wd mode
Recommended yes
Comments: Quadra-Trac works great. However, I wish it could be shifted out of 4WD sometimes for more performance. SelecTrac allows you to do this, however, Quadra-Trac does not.
Price $12345
Pros Aweosme, great selection
Cons Nothing, just a high low range.
Recommended yes
Comments: I love this t-case beacuse of all the options and it is really heavy. 2HI, 4HI PART-TIME, 4HI FULL-TIME, NEUTRAL, 4LO. The low range is 2.73:1. I wold like 4:1 or at very least 3:1.
Price $150
Pros Strong, 5 selectable ranges
Cons None
Recommended yes
Comments: I6 242 in my V8, just needed to swap input shafts. Not front shaft yet so can't test.
1 - 20 of 24 Posts
