My jeep died while driving. codes PO 700 and PO 562 under voltage. new alternator, cam shaft and crankshaft sensors, new pcm and still cranks no start. same codes. Fuel rail pressurized, battery holds charge, fuses ok. HELP!!
check and post furl pressure PSI.im thinking you are just using the key trick.
I swapped relay with another- no help.Have you checked/bypassed the ASD relay and checked for spark? The ASD relay cuts power to both the injectors and coils, otherwise things seem to work OK.
P0700 indicates the Transmission Control Module (TCM) detected a problem and set a trouble code in memory. You have to read the TCM module for the codes. Those codes may give you a clue. I think some of those codes could prevent the engine from starting. If you have a NAG transmission, the TCM is a separate module. The corporate transmission control software resides in the PCM with some functions in the transmission valve body.
My book says that PO562 is both low and high voltage. It is set when the system voltage is less than a calibrated value for 10 seconds or rises above 15.75 volts
Otherwise check why the PCM and probably TCM are thinking there is a voltage problem. Check for chafed or damaged wires, pushed pins, shorts, bad grounds, corrosion in connectors, rodent damage.... etc. I hear replacement PCMs have more than the usual problems.
Do you have remote start, if so have you tried that?
2005 Liberty 3.7 V6. I purchased it last July and it ran great until April this year. Engine lite came on while driving and it died within 5 minutes. Using my BlueDriver which sends info to the app on my phone. The reports show no other codes.what year liberty?
P0700 suggests there are transmission codes, are you using a scanner?
As someone tries to start jeep check for inj pulsing or spark plugs firing.
As helper tries to start jeep spray some , brake clean, carb cleaner or start fluid* into TB - tell us did engine fire and try to start on the spray.
* starting fluid is last on my list - I think its a little to volatile, called boom boom juice for a reason.
PS - if you still have your old PCM keep it.
did not fix the problem. sorry typo2005 Liberty 3.7 V6. I purchased it last July and it ran great until April this year. Engine lite came on while driving and it died within 5 minutes. Using my BlueDriver which sends info to the app on my phone. The reports show no other codes.
There over 55psi in fuel rail. Using starter fluid did nothing… just cranked. Weak or no spark. No ele to spark plugs or injectors. tested with trouble light and meter.
I still have on old pcm. The new one did fix the problem. Why “keep it”?
Battery neg post cable was loose, battery died, recharged, checked 12.8V - all good cellsit does NOT start at all not for @ 2seconds then cut off or when using starting fluid.
ony code is P0700 and P0562?
p0562 - battery OK, did you have to recharge or jump? we will check charging when its running.
Lets see if ASD is closing,
1st remember the 2second time out, if the engine does NOT start in 2seconds the ASD opens meaning no power to injectors, ign etc. That time can make checking a 2 person job.
SO as someone tries to start jeep is there 12v at coil or injector? pick one coil or inj - either wire.
You could jump inj or coil with a test light - it should flash when cranking.
I'm curious WHY did you replace PCM?
how many connectors were on PCM? 3 or 4?
I do understand the communication with the TCP. I was following the Jeep mechanic’s advice. Thankyou.1st lets put to rest the P0700 - see attachment - ALL it indicates is that the TCM has requested the CEL on as there are transmission issues.
Checking voltage at coil - see attachment unplug connector when key moved to start or run is there 12v at red wire center of connector.
Then jump the wires 1 to 2 with test light the light should flash as someone cranks eng.
See attachment PDC check f#6 and #24
there’s no voltage at center red wire of coil connector with test light with the key in in position. Much Appreciated!
I’m confused with starting fluid running in engine a couple of seconds. I rejected the pressure in rail - 50psi holding steady 20 minutes. i’m just a diy guy who’s always maintained my own vehicles. I’m new to all these sensors in this Jeep. You’re greatly appreciated.
I spilled the spark plug connected the coil and turned the engine over. I GOT SPARK!I do understand the communication with the TCP. I was following the Jeep mechanic’s advice. Thankyou.
there’s no voltage at center red wire of coil connector with test light.
the spark is orange red. isn’t that weak…low voltage? a blue or white would be stronger?engine is cranking - you have spark* next is injector pulsing.
fuse #26 a 15amp in the PDC. Don't just look at fuse probe multimeter or with test light.
Often just looking fails to see the break in fuse.
*We might want to check spark - is there a yellow, blue or white snap to it ?
Confirm spark at several plug wires.
FYI spec for fuel pressure is 58 psi +/- 5 psi so you are good.
spark plugs are NGK-ZFR 6FGPYes orange red is not a hot spark, and battery voltage would be first check.
Check battery record voltage.
Compare spark with other cylinders.
Post what brand plugs and rating you are running.
all cylinder plugs (6) flash red orange
Battery tests 12.7V
don’t understand ‘rating I am running’
Tested battery CCA meter fell to just above10v
