Status
Not open for further replies.
1 - 10 of 10 Posts
Standard acronyms used on the forum:
BL - Body Lift
CV Joint - Constant Velocity Joint
I4 - Inline engine, 4 cylinder, 2.5L
I6 - Inline engine, 6 cylinder, 4.2L or 4.0L
V6 - Engine used in Libery and JK - 3.7 litre
V8 - Engine used in Grand Cherokees
MML - Motor Mount Lift
RTI - Ramp Travel Index
SYE - Slip Yoke Eliminator
Does the JK stand for anything? - It does not mean Just Kidding as some people have suggested.
Something popped, now my steering is loose to the left.
Symptom: I was making a left-hand turn at an intersection and during the turn, I heard something pop on the front passenger side of the Jeep. Now my steering wheel is loose towards the left. The Jeep still seems to turn okay, but I've got to turn the wheel more for left turns and sometimes it causes the ESP to engage.
Fix: Common problem. The track-bar mount on the axle has been known to break the welds. Take the Jeep to the dealership for re-weld (under warranty), get denied and laugh as they offer a completely unnecessary alternative solution that'll cost you thousands of dollars and waste copious amounts of your time), or have an offroad shop build some gussets and weld that sucker up properly.
Picture below courtesy of DeepSky
The grill is made of plastic! - You are right. In the case of a major hit in very cold weather from a large rock, the plastic might crack, or in extreme cases break. Cherokee, Grand Cherokee and other Jeeps also have plastic grills on them, and in general they have faired fairly well over the years on trail and on the city streets and highways. It is part of the cost-savings / weight savings on the new JK.
The auto door-locks are driving me crazy. How do I make them not automagically lock the doors? - Shut the doors and turn the ignition key from "off" to "on" (stop turning the key at the point just before the engine starts). Do this five times. On the fifth time the key should be in the "on" position, push up on the power door lock.
To set for all doors to unlock together, follow the same proceedure, except press up on the power door lock 2 times.
Note: It has been said that it might take 6 turns of the ignition key to make the computer recognize the new door-lock desire.
I want more power. Is there going to be other options for engines? - At this point in time the only engine options from the factory are the gas engine in North America and a diesel or gas in Europe (and the rest of the world). There are companies that are installing Hemi engines into new JK's, but there is no official word from Jeep that they will do that from the factory. There are issues related to the CAFE standards that will need to be worked out prior to having more power from the factory in the JK. There are companies that are building superchargers for the JK's engine right now, and should be available to the public shortly.
My Jeep hates the cold! - This is especially true for the standard transmission Jeeps. The shift-boots can stiffen up at temperatures below freezing. To help remedy this situation, start your Jeep and shift the transfer-case into neutral. Slowly work the gears from first to 5th (or 6th if equipp'd) and back to 1st again. Do this over about 5 minutes (or while you are removing ice / snow from the exterior of your Jeep). You may notice your engine RPM dropping with the load of the transmission - this is normal. This proceedure will warm up the fluids in the transfer case prior to putting significant load on it, and help to warm up the fluids in the transfer-case as well.
More Questions and Answers to be added to this as time goes on. If there is something you feel should be added, please PM one of the moderators of this section to add a question and answer that you provide. Many thanks to JeepInfoCenter for information contained in this FAQ
Discussion Starter · #2 ·
Order Status​
Originally posted by Hip2u77:
If you have an order which is in D status or further along in the process then your dealer should have an idea of when your vehicle will arrive.
If your vehicle is in anything before D status (includes BA, BG, and BX) then the following applies to you and is the same for every dealer in the nation. No dealer can get by the following:
WRANGLER
(JKTM74)(w23C & 24C) Wrangler Unlimit ed X 4x2 4 DR Sched. Out Nov.
(JKJL72)(w/23B, 24B & 24 S) Wrangler X 4x4 2 DR Sched. Out Nov.
(JKJM74) Wrangler Unlimit ed X 4x4 4 DR Sched. Out Nov.
(JKJP74)(w/24G) Wrangler Unlimit ed Sahara 4x4 4 DR Sched. Out Nov.
(JKJS72) Wrangler Rubicon 4x4 2 DR Sched. Out Nov.
(JKJS74) Wrangler Unlimited Rubicon 4x4 4 DR Sched. Out Nov.
"Sched. Out November" means that if you have any of the above ordered then your dealer will not even have a possible allocation of your vehicle until the December allocation is issued. That means that the next possible build date you will have is for December Build. December build should start in the last quarter of November.
Chrysler does not give priority to sold orders other than building them first for a dealer. They do not get put ahead of other dealers orders. Some might think this is not fair, but it is. Each dealer gets a certain amount of allocation based on previous sales. This gives each dealer the appropriate amount of vehicles based on sales history.
If the factory did just build any sold order ahead of other for-stock units, what would stop me from just putting a bunch of names on every order and then getting a ton of Wranglers built why every other dealer just had to wait? That is why each dealer is allocated a certain amount, and that allocation covers sold orders as well.
It is very important to discuss this with the dealer when ordering a vehicle. Asking questions about their allocation in past months, what they expect their allocation to be, and how many other sold orders are in their pipeline are very important.
A little bit more on allocation:
Allocation comes out on each Monday 4 times a month. So if there is 5 weeks then the 5th week is skipped. Allocation is issued by quarter for the following month of build dates. So allocation that I receive this coming Monday (October 23rd) will be for the 4th quarter build dates of November.
We get allocation for both 2 door Wranglers and 4 Door Wranglers. Last week I received an allocation for 2 of the 4-door and 5 of the 2-door. That means that I was able to get 2 of the Unlimited's scheduled based on the regulations listed above. The mix can very week to week for many reasons.
Allocation priority is given to sold orders for each dealership and will usually get built quicker, but they will not be placed in a priority position above any other dealership.
How do I check on my new order status?
DaimlerChrysler Customer Assistance Center
1-800-992-1997 (Mon-Fri 8am-5pm)
Press: 5,2,1,2,0,3. You will need your VON before you call.
They may give you a order status code, here is what each code means.
BA - order in system
BB - review by fleet department
BD - special equipment processing
BE - edit error
BG - passed edit n/a for schedule
BGL - edit ok parts unavailable
BX - passed edit available for schedule
C - sub firm
D - firm schedule - dealer has allocation and all parts available
D - 1 gateline schedule - scheduled to be built
E - frame
F - paint
G - trim
I - built not ok'd
J - built ok'd
JB - shipped to body vendor
JE - emission check
JS - shipped to storage
KZ - released by plant , invoiced
KZL - released - not shipped
KZM - first rail departure
KZN - first rail arrival
KZO - delayed/recieved
KZOA - plant holds
KZOB - zone/distribution holds
KZOC - carrier delays
KZOD - carrier holds
KZOE - mis-shipped vehicle
KZOF - show/test vehicle
KZOG - damaged vehicle
KZOH - all other reasons
KZT - second rail departure
KZU - second rail arrival
KZX - delivered to dealer
ZA - canceled
Locked @ both ends
Tires
32" tires
no modifications
33" tires
3/4" spacer lift front minimum (2" BB preferred)
no gear replacement needed, 4.10's preferred.
34-35" tires
minimum 2.5" BB/3" lift,
will rub at full flex with 2.5BB
trim/remove front air dam
new gears may be needed on automatic transmissions, overdrive not able to be used (possible upgrade to 4.88's or 5.13's but not necessary)
4.10's ok for manual, but 6th gear obsolete.
trim pinch weld at rear tire
36-37" tires
minimum 3.5-4" lift
some trimming may be required on front bumper/fenderwells
new gears 4.88 or 5.13's (4.10s will be insufficeient for both manual and auto)
Wheels
JK wheels are 5 on 5 bolt spacing
backspacing - distance from the rear of the wheel to the mounting surface (inches)
offset - distance from the center of the wheel to the moounting surface (+/-mm)
15" wheel
some 15 wheels will fit depending on the manufacturer.
3.75 to 4.25 backspacing will be required depending on style and width of rim.
16" wheel
factory 16" wheels are 7" wide with 5.5" backspacing. (standard and optional X)
most/all aftermarket 16" wheels will fit reguardless of backspacing.
up to an 11.5" wide tire can be placed on the factory wheels but 1-1.5" wheel spacer will be needed
17" wheel
factory 17" wheels are 7.5" wide with 6" backspacing. (optional X, Sahara and Rubicon)
Optional X and Sahara 17" wheels are painted silver, Rubicon have a machined face
most/all aftermarket 17" wheels will fit reguardless of backspacing.
up to an 12.5" wide tire can be placed on the factory wheels but 1-1.5" wheel spacer will be needed
18" wheel
factory 18" wheels are 7.5" wide with 6" backspacing. (optional Sahara)
up to an 12.5" wide tire can be placed on the factory wheels but 1-1.5" wheel spacer will be needed__________________
Locked @ both ends
Trouble codes
Jeep*JK*Computer*Diagnostic*Codes
B1001 **‐** A/C*SWITCH*REQUEST*INPUT*CIRCUIT*LOW*(ATC*&*MTC)
B1002 **‐** A/C*SWITCH*REQUEST*INPUT*CIRCUIT*HIGH*(CCN)
B1016 **‐** REAR*DEFROST*SWITCH*INPUT*CIRCUIT*LOW*(CCN)
B1031 **‐** EVAPORATOR*FIN*TEMPERATURE*SENSOR*CIRCUIT*LOW*(MTC )
B1032 **‐** EVAPORATOR*FIN*TEMPERATURE*SENSOR*CIRCUIT*HIGH*(MT C)
B10C1 **‐** A/C*SELECT*SWITCH*STUCK*(CCN)
B10C2 **‐** REAR*DEFROST*SWITCH*STUCK*‐*CLUSTER
B123F **‐** MENU*SWITCH*STUCK
B127A **‐** COMPASS*PERFORMANCE
B1288 **‐** TRIP/TOGGLE*SWITCH*PERFORMANCE
B1401 **‐** FRONT*LEFT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B1402 **‐** FRONT*LEFT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B1403 **‐** FRONT*LEFT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B1405 **‐** FRONT*RIGHT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B1406 **‐** FRONT*RIGHT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B1407 **‐** FRONT*RIGHT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B1409 **‐** REAR*LEFT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B140A **‐** REAR*LEFT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B140B **‐** REAR*LEFT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B140D **‐** REAR*RIGHT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B140E **‐** REAR*RIGHT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B140F **‐** REAR*RIGHT*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B1420 **‐** AUDIO*CASSETTE*ERROR/INOPERABLE*CASSETTE
B1421 **‐** AUDIO*CD*READ*ERROR/INOPERABLE*DISC
B1422 **‐** AUDIO*DVD*READ*ERROR/INOPERABLE*DISC
B1423 **‐** VES*DVD*READ*ERROR/INOPERABLE*DISC
B1424 **‐** IMPROPER*DVD‐WRONG*REGION
B1429 **‐** RADIO*DISPLAY*HIGH*TEMPERATURE
B142A **‐** RADIO*UNIT*HIGH*TEMPERATURE
B142C **‐** VES*VIDEO*SCREEN*DISCONNECTED
B142D **‐** AUDIO*ANTENNA*NOT*CONNECTED
B142E **‐** GPS*ANTENNA*NOT*CONNECTED
B142F **‐** SATELLITE*RADIO*ANTENNA*NOT*CONNECTED
B1430 **‐** SATELLITE*RADIO*ANTENNA*INTERNAL*PERFORMANCE
B1460 **‐** CHANNEL*1*AUDIO*SPEAKER*OUTPUT*CIRCUIT*PERFORMANCE
B1461 **‐** CHANNEL*1*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B1462 **‐** CHANNEL*1*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B1463 **‐** CHANNEL*1*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B1464 **‐** CHANNEL*1*AUDIO*SPEAKER*OUTPUT*CIRCUIT*SHORTED*TOG ETHER
B1465 **‐** CHANNEL*2*AUDIO*SPEAKER*OUTPUT*CIRCUIT*PERFORMANCE
B1466 **‐** CHANNEL*2*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B1467 **‐** CHANNEL*2*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B1468 **‐** CHANNEL*2*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B1469 **‐** CHANNEL*2*AUDIO*SPEAKER*OUTPUT*CIRCUIT*SHORTED*TOG ETHER
B146A **‐** CHANNEL*3*AUDIO*SPEAKER*OUTPUT*CIRCUIT*PERFORMANCE
B146B **‐** CHANNEL*3*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B146C **‐** CHANNEL*3*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B146D **‐** CHANNEL*3*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B146E **‐** CHANNEL*3*AUDIO*SPEAKER*OUTPUT*CIRCUIT*SHORTED*TOG ETHER
B146F **‐** CHANNEL*4*AUDIO*SPEAKER*OUTPUT*CIRCUIT*PERFORMANCE
B1470 **‐** CHANNEL*4*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B1471 **‐** CHANNEL*4*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B1472 **‐** CHANNEL*4*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B1473 **‐** CHANNEL*4*AUDIO*SPEAKER*OUTPUT*CIRCUIT*SHORTED*TOG ETHER
B1474 **‐** CHANNEL*5*AUDIO*SPEAKER*OUTPUT*CIRCUIT*PERFORMANCE
B1475 **‐** CHANNEL*5*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B1476 **‐** CHANNEL*5*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B1477 **‐** CHANNEL*5*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B1478 **‐** CHANNEL*5*AUDIO*SPEAKER*OUTPUT*CIRCUIT*SHORTED*TOG ETHER
B1479 **‐** CHANNEL*6*AUDIO*SPEAKER*OUTPUT*CIRCUIT*PERFORMANCE
B147A **‐** CHANNEL*6*AUDIO*SPEAKER*OUTPUT*CIRCUIT*LOW
B147B **‐** CHANNEL*6*AUDIO*SPEAKER*OUTPUT*CIRCUIT*HIGH
B147C **‐** CHANNEL*6*AUDIO*SPEAKER*OUTPUT*CIRCUIT*OPEN
B147D **‐** CHANNEL*6*AUDIO*SPEAKER*OUTPUT*CIRCUIT*SHORTED*TOG ETHER
B1613 **‐** PANEL*ILLUMINATION*CONTROL*CIRCUIT*LOW
B1615 **‐** PANEL*ILLUMINATION*CONTROL*CIRCUIT*OPEN
B161A **‐** COURTESY/DOME*LAMP*CONTROL*CIRCUIT
B161E **‐** READING*LAMP*CONTROL*CIRCUIT
B162B **‐** LEFT*LOW*BEAM*CONTROL*CIRCUIT*LOW
B162C **‐** LT*LOW*BEAM*CONTROL*CKT*HI
B162F **‐** RIGHT*LOW*BEAM*CONTROL*CIRCUIT*LOW
B1630 **‐** RIGHT*LOW*BEAM*CONTROL*CIRCUIT*HIGH
B1633 **‐** LEFT*HI*BEAM*CONTROL*CIRCUIT*LOW
B1634 **‐** LEFT*HI*BEAM*CONTROL*CIRCUIT*HIGH
B1637 **‐** RIGHT*HI*BEAM*CONTROL*CIRCUIT*LOW
B1638 **‐** RIGHT*HI*BEAM*CONTROL*CIRCUIT*HIGH
B163B **‐** FRONT*LEFT*TURN*CONTROL*CIRCUIT*LOW
B163C **‐** FRONT*LEFT*TURN*CONTROL*CIRCUIT*HIGH
B163F **‐** FRONT*RIGHT*TURN*CONTROL*CIRCUIT*LOW
B1640 **‐** FRONT*RIGHT*TURN*CONTROL*CIRCUIT*HIGH
B1643 **‐** REAR*LEFT*TURN*CONTROL*CIRCUIT*LOW
B1644 **‐** REAR*LEFT*TURN*CONTROL*CIRCUIT*HIGH
B1644 **‐** RIGHT*STOP*LAMP*CONTROL*CIRCUIT*HIGH
B1647 **‐** REAR*RIGHT*TURN*CONTROL*CIRCUIT*LOW
B1648 **‐** REAR*RIGHT*TURN*CONTROL*CIRCUIT*HIGH
B1663 **‐** REAR*FOG*LAMP*CONTROL*CIRCUIT*LOW
B1664 **‐** REAR*FOG*LAMP*CONTROL*CIRCUIT*HIGH
B166B **‐** LEFT*TRAILER*TOW*LAMP*CONTROL*CIRCUIT*LOW
B166C **‐** LEFT*TRAILER*TOW*LAMP*CONTROL*CIRCUIT*HIGH
B166F **‐** RIGHT*TRAILER*TOW*LAMP*CONTROL*CIRCUIT*LOW
B1670 **‐** RIGHT*TRAILER*TOW*LAMP*CONTROL*CIRCUIT*HIGH
B16B1 **‐** LEFT*STOP*LAMP*CONTROL*CIRCUIT*HIGH
B16F8 **‐** FRONT*LEFT*FOG*LAMP*CONTROL*CIRCUIT*LOW
B16F9 **‐** FRONT*LEFT*FOG*LAMP*CONTROL*CIRCUIT*HIGH
B16FC **‐** FRONT*RIGHT*FOG*LAMP*CONTROL*CIRCUIT*LOW
B16FD **‐** FRONT*RIGHT*FOG*LAMP*CONTROL*CIRCUIT*HIGH
B17B8 **‐** LEFT*STOP*LAMP*CONTROL*CIRCUIT*OVERCURRENT
B17B9 **‐** RIGHT*STOP*LAMP*CONTROL*CIRCUIT*OVERCURRENT
B17BA **‐** HEADLAMP*LEVELING*MOTOR*CONTROL*CIRCUIT*OVERCURREN T
B17BF **‐** LEFT*SIDEMARKER*LAMP*CONTROL*CIRCUIT*OVERCURRENT
B17C4 **‐** RIGHT*SIDEMARKER*LAMP*CONTROL*CIRCUIT*OVERCURRENT
B1801 **‐** DRIVER*DOOR*LOCK/UNLOCK*SWITCH*CIRCUIT*LOW*‐*CLUSTER
B1806 **‐** PASSENGER*DOOR*LOCK/UNLOCK*SWITCH*CIRCUIT*LOW*‐*TIPM
B1934 **‐** DRIVER*DOOR*LOCK/UNLOCK*SWITCH*CIRCUIT*STUCK*‐*CLUSTER
B1935 **‐** PASSENGER*DOOR*LOCK/UNLOCK*SWITCH*CIRCUIT*STUCK*‐*TIPM
B1A08 **‐** RKE*FOB*1*PERFORMANCE
B1A09 **‐** RKE*FOB*2*PERFORMANCE
B1A0A **‐** RKE*FOB*3*PERFORMANCE
B1A0B **‐** RKE*FOB*4*PERFORMANCE
B1A0C **‐** RKE*FOB*5*PERFORMANCE
B1A0D **‐** RKE*FOB*6*PERFORMANCE
B1A0E **‐** RKE*FOB*7*PERFORMANCE
B1A0F **‐** RKE*FOB*8*PERFORMANCE
B1A10 **‐** RKE*FOB*1*BATTERY*LOW
B1A11 **‐** RKE*FOB*2*BATTERY*LOW
B1A12 **‐** RKE*FOB*3*BATTERY*LOW
B1A13 **‐** RKE*FOB*4*BATTERY*LOW
B1A14 **‐** RKE*FOB*5*BATTERY*LOW
B1A15 **‐** RKE*FOB*6*BATTERY*LOW
B1A16 **‐** RKE*FOB*7*BATTERY*LOW
B1A17 **‐** RKE*FOB*8*BATTERY*LOW
B1A20 **‐** PRE‐ARM*TIMEOUT
B1A23 **‐** RKE*RECEIVER*PERFORMANCE
B1A24 **‐** KEY*NOT*PROGRAMMED
B1A25 **‐** INVALID*KEY
B1A26 **‐** MAXIMUM*NUMBER*OF*KEYS*PROGRAMMED
B1A27 **‐** SKREEM*PROGRAMMING*PERFORMANCE
B1A28 **‐** ECM*MISMATCH*WITH*SKIM
B1A29 **‐** SKIM*BASESTATION*MISMATCH
B1A3C **‐** INTERNAL*SIREN*BATTERY
B1A3D **‐** SIREN*BATTERY*/*LOSS*OF*POWER*SUPPLY
B1A3E **‐** SIREN/ITM*MISMATCH
B1A3F **‐** ITM*ARMING*SEQUENCE*PERFORMANCE
B1A48 **‐** INTRUSION*SENSOR*1*INTERNAL
B1A5F **‐** INTRUSION*SENSOR*2*INTERNAL
B1A6D **‐** INTRUSION*SENSOR*3*INTERNAL
B1B00 **‐** DRIVER*AIRBAG*SQUIB*1*CIRCUIT*LOW
B1B01 **‐** DRIVER*AIRBAG*SQUIB*1*CIRCUIT*HIGH
B1B02 **‐** DRIVER*AIRBAG*SQUIB*1*CIRCUIT*OPEN
B1B03 **‐** DRIVER*AIRBAG*SQUIB*1*CIRCUIT*SHORTED*TOGETHER
B1B04 **‐** DRIVER*AIRBAG*SQUIB*2*CIRCUIT*LOW
B1B05 **‐** DRIVER*AIRBAG*SQUIB*2*CIRCUIT*HIGH
B1B06 **‐** DRIVER*AIRBAG*SQUIB*2*CIRCUIT*OPEN
B1B07 **‐** DRIVER*AIRBAG*SQUIB*2*CIRCUIT*SHORTED*TOGETHER
B1B08 **‐** PASSENGER*AIRBAG*SQUIB*1*CIRCUIT*LOW
B1B09 **‐** PASSENGER*AIRBAG*SQUIB*1*CIRCUIT*HIGH
B1B0A **‐** PASSENGER*AIRBAG*SQUIB*1*CIRCUIT*OPEN
B1B0B **‐** PASSENGER*AIRBAG*SQUIB*1*CIRCUIT*SHORTED*TOGETHER
B1B0C **‐** PASSENGER*AIRBAG*SQUIB*2*CIRCUIT*LOW
B1B0D **‐** PASSENGER*AIRBAG*SQUIB*2*CIRCUIT*HIGH
B1B0E **‐** PASSENGER*AIRBAG*SQUIB*2*CIRCUIT*OPEN
B1B0F **‐** PASSENGER*AIRBAG*SQUIB*2*CIRCUITS*SHORTED*TOGETHER
B1B54 **‐** 1ST*ROW*PASSENGER*SEAT*BELT*SENSOR*CIRCUIT*LOW
B1B55 **‐** 1*ST*ROW*PASSENGER*SEAT*BELT*SENSOR*CIRCUIT*HIGH
B1B56 **‐** 1*ST*ROW*PASSENGER*SEAT*BELT*SENSOR*CIRCUIT*OPEN
B1B70 **‐** UP‐FRONT*LEFT*SATELLITE*ACCELERATION*SENSOR*INTERN AL
B1B71 **‐** UP‐FRONT*RIGHT*SATELLITE*ACCELERATION*SENSOR*INTER NAL
B1B72 **‐** LEFT*SIDE*SATELLITE*ACCELERATION*SENSOR*1*INTERNAL
B1B75 **‐** RIGHT*SIDE*SATELLITE*ACCELERATION*SENSOR*1*INTERNA L
B1B78 **‐** PASSENGER*SEAT*WEIGHT*SENSOR*3*‐*LEFT*FRONT*PERFOR MANCE
B1B79 **‐** PASSENGER*SEAT*WEIGHT*SENSOR*3*‐*LEFT*FRONT*INPUT* CIRCUIT*LOW
B1B7A **‐** PASSENGER*SEAT*WEIGHT*SENSOR*3*‐*LEFT*FRONT*INPUT* CIRCUIT*HIGH
B1B7D **‐** PASSENGER*SEAT*WEIGHT*SENSOR*2*‐*RIGHT*FRONT*PERFO RMANCE
B1B7E **‐** PASSENGER*SEAT*WEIGHT*SENSOR*2*‐*RIGHT*FRONT*INPUT *CIRCUIT*LOW
B1B7F **‐** PASSENGER*SEAT*WEIGHT*SENSOR*2*‐*RIGHT*FRONT*INPUT *CIRCUIT*HIGH
B1B82 **‐** PASSENGER*SEAT*WEIGHT*SENSOR*4*‐*LEFT*REAR*PERFORM ANCE
B1B83 **‐** PASSENGER*SEAT*WEIGHT*SENSOR*4*‐*LEFT*REAR*INPUT*C IRCUIT*LOW
B1B84 **‐** PASSENGER*SEAT*WEIGHT*SENSOR*4*‐*LEFT*REAR*INPUT*C IRCUIT*HIGH
B1B87 **‐** PASSENGER*SEAT*WEIGHT*SENSOR*1*‐*RIGHT*REAR*PERFOR MANCE
B1B88 **‐** PASSENGER*SEAT*WEIGHT*SENSOR*1*‐*RIGHT*REAR*INPUT* CIRCUIT*LOW
B1B89 **‐** PASSENGER*SEAT*WEIGHT*SENSOR*1*‐*RIGHT*REAR*INPUT* CIRCUIT*HIGH
B1B8D **‐** DRIVER*SEAT*TRACK*POSITION*SENSOR*CIRCUIT*LOW
B1B8E **‐** DRIVER*SEAT*TRACK*POSITION*SENSOR*CIRCUIT*HIGH
B1B8F **‐** DRIVER*SEAT*TRACK*POSITION*SENSOR*CIRCUIT*OPEN
B1B93 **‐** PASSENGER*SEAT*TRACK*POSITION*SENSOR*CIRCUIT*LOW
B1B94 **‐** PASSENGER*SEAT*TRACK*POSITION*SENSOR*CIRCUIT*HIGH
B1B95 **‐** PASSENGER*SEAT*TRACK*POSITION*SENSOR*CIRCUIT*OPEN
B1BA5 **‐** AIRBAG*SQUIB*CONFIGURATION*MISMATCH
B1BA6 **‐** OCCUPANT*CLASSIFICATION*UNDETERMINED
B1BA7 **‐** OCCUPANT*CLASSIFICATION*SYSTEM*VERIFICATION*REQUIR ED
B1BA8 **‐** OCM*SYSTEM*OUT*OF*CALIBRATION/NOT*CALIBRATED
B1BAA **‐** OCCUPANT*CLASSIFICATION*MODULE*CONFIGURATION*MISMA TCH
B1BBA **‐** PASSENGER*SEAT*WEIGHT*SENSOR*SUPPLY*CIRCUIT
B1BBB **‐** PASSENGER*SEAT*WEIGHT*SENSOR*INPUTS*SHORTED*TOGETH ER
B1BBC **‐** OCS*NEGATIVE*SYSTEM*WEIGHT
B1BBD **‐** OCM*CURRENT*CONFIGURATION*TABLE*UNPROGRAMMED
B1BC7 **‐** DEPLOYMENT*DATA*RECORD*FULL
B1C27 **‐** LEFT*SIDE*SEAT*THORAX*SQUIB*1*LOW
B1C28 **‐** LEFT*SIDE*SEAT*THORAX*SQUIB*1*HIGH
B1C29 **‐** LEFT*SIDE*SEAT*THORAX*SQUIB*1*OPEN
B1C2A **‐** LEFT*SIDE*SEAT*THORAX*SQUIB*1*SHORTED*TOGETHER
B1C2B **‐** RIGHT*SIDE*SEAT*THORAX*SQUIB*1*LOW
B1C2C **‐** RIGHT*SIDE*SEAT*THORAX*SQUIB*1*HIGH
B1C2D **‐** RIGHT*SIDE*SEAT*THORAX*SQUIB*1*OPEN
B1C2E **‐** RIGHT*SIDE*SEAT*THORAX*SQUIB*1*SHORTED*TOGETHER
B1C38 **‐** 1ST*ROW*DRIVER*RETRACTOR*PRETENSIONER*CIRCUIT*LOW
B1C39 **‐** 1ST*ROW*DRIVER*RETRACTOR*PRETENSIONER*CIRCUIT*HIGH
B1C3A **‐** 1ST*ROW*DRIVER*RETRACTOR*PRETENSIONER*CIRCUIT*OPEN
B1C3B **‐** 1ST*ROW*DRIVER*RETRACTOR*PRETENSIONER*CIRCUIT*SHOR TED*TOGETHER
B1C47 **‐** 1ST*ROW*PASSENGER*RETRACTOR*PRETENSIONER*CIRCUIT*L OW
B1C48 **‐** 1ST*ROW*PASSENGER*RETRACTOR*PRETENSIONER*CIRCUIT*H IGH
B1C49 **‐** 1ST*ROW*PASSENGER*RETRACTOR*PRETENSIONER*CIRCUIT*O PEN
B1C4A **‐** 1ST*ROW*PASSENGER*RETRACTOR*PRETENSIONER*CIRCUIT*S HORTED*TOGETHER
B2101 **‐** IGNITION*RUN/START*INPUT*CIRCUIT*LOW
B2102 **‐** IGNITION*RUN/START*INPUT*CIRCUIT*HIGH
B210A **‐** SYSTEM*VOLTAGE*LOW*(WCM)
B210B **‐** SYSTEM*VOLTAGE*HIGH*(WCM)
B210D **‐** BATTERY*VOLTAGE*LOW*(WCM)
B210E **‐** BATTERY*VOLTAGE*HIGH*(WCM)
B212C **‐** IGNITION*RUN/START*INPUT*CIRCUIT*OPEN
B212D **‐** IGNITION*RUN*ONLY*INPUT*CIRCUIT*OPEN
B2142 **‐** IGNITION*OFF*DRAW*(IOD)*FUSE*NOT*PRESENT
B219A **‐** IGNITION*UNLOCK*RUN/START*CONTROL*CIRCUIT*OVERCURRENT
B219F **‐** IGNITION*OFF*DRAW*(IOD)*FUSE*BLOWN
B2201 **‐** CALIBRATION*MISMATCH
B2204 **‐** ECU*CONFIGURATION*MISMATCH
B2205 **‐** ORIGINAL*VIN*MISSING/MISMATCH
B2206 **‐** CURRENT*VIN*MISSING/MISMATCH
B2206 **‐** CURRENT*VIN*MISSING*/*MISMATCH
B2207 **‐** OCCUPANT*RESTRAINT*CONTROLLER*INTERNAL*1
B2208 **‐** OCCUPANT*RESTRAINT*CONTROLLER*INTERNAL*2
B2209 **‐** OCCUPANT*RESTRAINT*CONTROLLER*INTERNAL*3
B220A **‐** OCCUPANT*RESTRAINT*CONTROLLER*INTERNAL*4
B220B **‐** OCCUPANT*RESTRAINT*CONTROLLER*FIRING*STORED*ENERGY
B220C **‐** OCCUPANT*RESTRAINT*CONTROLLER*ACCELEROMETER*1*INTE RNAL
B220D **‐** OCCUPANT*RESTRAINT*CONTROLLER*ACCELEROMETER*2*INTE RNAL
B2212 **‐** OCCUPANT*CLASSIFICATION*MODULE*INTERNAL
B2222 **‐** SATELLITE*RADIO*RECEIVER*INTERNAL
B2224 **‐** SKREEM*INTERNAL
B2229 **‐** SKREEM*INTERNAL*‐*SKIM*IMMOBILIZER
B222A **‐** VEHICLE*LINE*MISMATCH
B222C **‐** VEHICLE*CONFIGURATION*NOT*PROGRAMMED
B223B **‐** VEHICLE*CONFIGURATION*MISMATCH
B223C **‐** INTRUSION*TRANSCEIVER*MODULE*INTERNAL
B223D **‐** OCCUPANT*CLASSIFICATION*MODULE*DTC*PRESENT
B2254 **‐** COLUMN*LOCK*MODULE*INTERNAL
B2304 **‐** WIPER*PARK*SWITCH*INPUT*CIRCUIT*LOW
B2305 **‐** WIPER*PARK*SWITCH*INPUT*CIRCUIT*HIGH
B230D **‐** REAR*WIPER*PARK*SWITCH*INPUT*CIRCUIT*LOW*(STUCK*LO W)
B230E **‐** REAR*WIPER*PARK*SWITCH*INPUT*CIRCUIT*HIGH*(STUCK*H IGH)
B2323 **‐** HEADLAMP*WASHER*MOTOR*CONTROL*CIRCUIT*LOW
B2324 **‐** HEADLAMP*WASHER*MOTOR*CONTROL*CIRCUIT*HIGH
B2339 **‐** HORN*SWITCH*STUCK
C0077 **‐** LOW*TIRE*PRESSURE
C1404 **‐** TRANSFER*CASE*RANGE*POSITION*SENSOR*CIRCUIT*LOW*(T IPM)
C1405 **‐** TRANSFER*CASE*RANGE*POSITION*SENSOR*CIRCUIT*HIGH*( TIPM)
C1417 **‐** FRONT*DIFFERENTIAL*CONTROL*CIRCUIT*LOW
C1418 **‐** FRONT*DIFFERENTIAL*CONTROL*CIRCUIT*HIGH
C141D **‐** REAR*DIFFERENTIAL*CONTROL*CIRCUIT*LOW
C141E **‐** REAR*DIFFERENTIAL*CONTROL*CIRCUIT*HIGH
C1501 **‐** TIRE*PRESSURE*SENSOR*1*INTERNAL
C1502 **‐** TIRE*PRESSURE*SENSOR*2*INTERNAL
C1503 **‐** TIRE*PRESSURE*SENSOR*3*INTERNAL
C1504 **‐** TIRE*PRESSURE*SENSOR*4*INTERNAL
C2100 **‐** BATTERY*VOLTAGE*LOW
C2101 **‐** BATTERY*VOLTAGE*HIGH
C2207 **‐** OFF*ROAD*ECU*INTERNAL
Locked @ both ends
P0016 ‐ Crankshaft/camshaft Timing Misalignment
P0031 ‐ O2 Sensor 1/1 Heater Circuit Low
P0032 ‐ O2 Sensor 1/1 Heater Circuit High
P0037 ‐ O2 Sensor 1/2 Heater Circuit Low
P0038 ‐ O2 Sensor 1/2 Heater Circuit High
P0051 ‐ O2 Sensor 2/1 Heater Circuit Low
P0052 ‐ O2 Sensor 2/1 Heater Circuit High
P0057 ‐ O2 Sensor 2/2 Heater Circuit Low
P0058 ‐ O2 Sensor 2/2 Heater Circuit High
P0071 ‐ Ambient Air Temperature Sensor Performance
P0072 ‐ Ambient Air Temperature Sensor Circuit Low
P0073 ‐ Ambient Air Temperature Sensor Circuit High
P0107 ‐ Manifold Absolute Pressure Sensor Circuit Low
P0108 ‐ Manifold Absolute Pressure Sensor Circuit High
P0111 ‐ Intake Air Temperature Sensor Rationality
P0112 ‐ Intake Air Temperature Sensor Circuit Low
P0113 ‐ Intake Air Temperature Sensor Circuit High
P0116 ‐ Engine Coolant Temperature Sensor Performance
P0117 ‐ Engine Coolant Temperature Sensor Circuit Low
P0118 ‐ Engine Coolant Temperature Sensor Circuit High
P0121 ‐ Throttle Position Sensor 1 Performance
P0122 ‐ Tps/apps Circuit Low
P0122 ‐ Throttle Position Sensor 1 Circuit Low
P0123 ‐ Tps/app Circuit High
P0123 ‐ Throttle Position Sensor 1 Circuit High
P0124 ‐ Tps/app Intermittent
P0125 ‐ Insufficient Coolant Temperature For Closed‐loop Fuel Control
P0128 ‐ Thermostat Rationality
P0129 ‐ Barometric Pressure Out‐of‐range Low
P0131 ‐ O2 Sensor 1/1 Circuit Low
P0132 ‐ O2 Sensor 1/1 Circuit High
P0133 ‐ O2 Sensor 1/1 Slow Response
P0135 ‐ O2 Sensor 1/1 Heater Performance
P0137 ‐ O2 Sensor 1/2 Circuit Low
P0138 ‐ O2 Sensor 1/2 Circuit High
P0139 ‐ O2 Sensor 1/2 Slow Response
P013a ‐ O2 Sensor 1/2 Slow Response ‐ Rich To Lean
P013c ‐ O2 Sensor 2/2 Slow Response ‐ Rich To Lean
P0141 ‐ O2 Sensor 1/2 Heater Performance
P0151 ‐ O2 Sensor 2/1 Circuit Low
P0152 ‐ O2 Sensor 2/1 Circuit High
P0153 ‐ O2 Sensor 2/1 Slow Response
P0155 ‐ O2 Sensor 2/1 Heater Performance
P0157 ‐ O2 Sensor 2/2 Circuit Low
P0158 ‐ O2 Sensor 2/2 Circuit High
P0159 ‐ O2 Sensor 2/2 Slow Response
P0161 ‐ O2 Sensor 2/2 Heater Performance
P0171 ‐ Fuel System 1/1 Lean
P0172 ‐ Fuel System 1/1 Rich
P0174 ‐ Fuel System 2/1 Lean
P0175 ‐ Fuel System 2/1 Rich
P0201 ‐ Fuel Injector 1 Circuit
P0202 ‐ Fuel Injector 2 Circuit
P0203 ‐ Fuel Injector 3 Circuit
P0204 ‐ Fuel Injector 4 Circuit
P0205 ‐ Fuel Injector 5 Circuit
P0206 ‐ Fuel Injector 6 Circuit
P0218 ‐ High Temperature Operation Activated
P0221 ‐ Throttle Position Sensor 2 Performance
P0222 ‐ Throttle Position Sensor 2 Circuit Low
P0223 ‐ Throttle Position Sensor 2 Circuit High
P0300 ‐ Multiple Cylinder Misfire
P0301 ‐ Cylinder 1 Misfire
P0302 ‐ Cylinder 2 Misfire
P0303 ‐ Cylinder 3 Misfire
P0304 ‐ Cylinder 4 Misfire
P0305 ‐ Cylinder 5 Misfire
P0306 ‐ Cylinder 6 Misfire
P0315 ‐ No Crank Sensor Learned
P0325 ‐ Knock Sensor 1 Circuit
P0335 ‐ Crankshaft Position Sensor Circuit
P0339 ‐ Crankshaft Position Sensor Intermittent
P0340 ‐ Camshaft Position Sensor Circuit
P0344 ‐ Camshaft Position Sensor Intermittent
P0401 ‐ Egr System Performance
P0403 ‐ Egr Solenoid Circuit
P0404 ‐ Egr Position Sensor Rationality Open
P0405 ‐ Egr Position Sensor Circuit Low
P0406 ‐ Egr Position Sensor Circuit High
P0420 ‐ Catalyst Efficiency (bank 1)
P0430 ‐ Catalyst Efficiency (bank 2)
P0440 ‐ General Evap System Failure
P0441 ‐ Evap Purge System Performance
P0443 ‐ Evap Purge Solenoid Circuit
P0452 ‐ Evap Pressure Switch Stuck Closed
P0455 ‐ Evap Purge System Large Leak
P0456 ‐ Evap Purge System Small Leak
P0457 ‐ Loose Fuel Cap
P0461 ‐ Fuel Level Sensor 1 Performance
P0462 ‐ Fuel Level Sensor 1 Circuit Low
P0463 ‐ Fuel Level Sensor 1 Circuit High
P0480 ‐ Cooling Fan 1 Control Circuit
P0481 ‐ Cooling Fan 2 Control Circuit
P0501 ‐ Vehicle Speed Sensor 1 Performance
P0503 ‐ Vehicle Speed Sensor 1 Erratic
P0506 ‐ Idle Speed Performance Lower Than Expected
P0507 ‐ Idle Speed Performance Higher Than Expected
P050b ‐ Cold Start Ignition Timing Performance
P050d ‐ Cold Start Rough Idle
P0513 ‐ Invalid Skim Key
P0522 ‐ Engine Oil Pressure Too Low
P0532 ‐ A/c Pressure Sensor Circuit Low
P0533 ‐ A/c Pressure Sensor Circuit High
P0562 ‐ Battery Voltage Low
P0563 ‐ Battery Voltage High
P0571 ‐ Brake Switch 1 Performance
P0572 ‐ Brake Switch 1 Stuck On
P0573 ‐ Brake Switch 1 Stuck Off
P0579 ‐ Speed Control Switch 1 Performance
P0580 ‐ Speed Control Switch 1 Circuit Low
P0581 ‐ Speed Control Switch 1 Circuit High
P0585 ‐ Speed Control Switch 1/2 Correlation
P0591 ‐ Speed Control Switch 2 Performance
P0592 ‐ Speed Control Switch 2 Circuit Low
P0593 ‐ Speed Control Switch 2 Circuit High
P0600 ‐ Serial Communication Link
P0601 ‐ Internal Memory Checksum Invalid
P0602 ‐ Control Module Programming Error/not Programmed
P0604 ‐ Internal Control Module Ram
P0605 ‐ Internal Control Module Rom
P0606 ‐ Internal Ecm Processor
P060b ‐ Etc A/d Ground Performance
P060d ‐ Etc Level 2 App Performance
P060e ‐ Etc Level 2 Tps Performance
P060f ‐ Etc Level 2 Ect Performance
P0613 ‐ Internal Transmission Processor
P061a ‐ Etc Level 2 Torque Performance
P061c ‐ Etc Level 2 Rpm Performance
P0622 ‐ Generator Field Control Circuit
P0627 ‐ Fuel Pump Control Circuit
P062c ‐ Etc Level 2 Mph Performance
P0630 ‐ Vin Not Programmed In Pcm
P0632 ‐ Odometer Not Programmed In Pcm
P0633 ‐ Skim Secret Key Not Stored In Pcm
P063a ‐ Generator Voltage Sense Circuit
P0642 ‐ Sensor Reference Voltage 1 Circuit Low
P0643 ‐ Sensor Reference Voltage 1 Circuit High
P0645 ‐ A/c Clutch Control Circuit
P0652 ‐ Sensor Reference Voltage 2 Circuit Low
P0653 ‐ Sensor Reference Voltage 2 Circuit High
P0685 ‐ Auto Shutdown Control Circuit
P0688 ‐ Auto Shutdown Sense Circuit Low
P0691 ‐ Cooling Fan 1 Control Circuit Low
P0692 ‐ Cooling Fan 1 Control Circuit High
P0693 ‐ Cooling Fan 2 Control Circuit Low
P0694 ‐ Cooling Fan 2 Control Circuit High
P0700 ‐ Transmission Control System (mil Request)
P0703 ‐ Brake Switch 2 Performance
P0706 ‐ Transmission Range Sensor Rationality
P0711 ‐ Transmission Temperature Sensor Performance
P0712 ‐ Transmission Temperature Sensor Low
P0713 ‐ Transmission Temperature Sensor High
P0714 ‐ Transmission Temperature Sensor Intermittent
P0716 ‐ Input Speed Sensor 1 Circuit Performance
P0721 ‐ Output Speed Sensor Circuit Performance
P0726 ‐ Engine Speed Input Circuit Range/performance
P0731 ‐ Gear Ratio Error In 1st
P0732 ‐ Gear Ratio Error In 2nd
P0733 ‐ Gear Ratio Error In 3rd
P0734 ‐ Gear Ratio Error In 4th
P0736 ‐ Gear Ratio Error In Reverse
P0740 ‐ Tcc Out Of Range
P0750 ‐ Lr Solenoid Circuit
P0755 ‐ 2/4 Solenoid Circuit
P0760 ‐ Od Solenoid Circuit
P0765 ‐ Ud Solenoid Circuit
P0841 ‐ Lr Pressure Switch Rationality
P0845 ‐ 2/4 Hydraulic Pressure Test
P0846 ‐ 2/4 Pressure Switch Rationality
P0850 ‐ Park/neutral Switch Performance
P0853 ‐ Overdrive/tow Switch Input Circuit Stuck
P0868 ‐ Line Pressure Low
P0869 ‐ Line Pressure High
P0870 ‐ Od Hydraulic Pressure Test
P0871 ‐ Od Pressure Switch Rationality
P0882 ‐ Tcm Power Input Low
P0883 ‐ Tcm Power Input High
P0884 ‐ Power Up At Speed
P0888 ‐ Transmission Relay Always Off
P0890 ‐ Switched Battery
P0891 ‐ Transmission Relay Always On
P0897 ‐ Transmission Fluid Deteriorated
P0933 ‐ Line Pressure Sensor Circuit Performance
P0934 ‐ Line Pressure Sensor Circuit Low
P0935 ‐ Line Pressure Sensor Circuit High
P0944 ‐ Loss Of Hydraulic Pump Prime
P0992 ‐ 2/4/od Hydraulic Pressure Test
P1115 ‐ General Temperature Rationality
P1128 ‐ Closed Loop Fueling Not Achieved ‐ Bank 1
P1129 ‐ Closed Loop Fueling Not Achieved ‐ Bank 2
P1273 ‐ A/c Clutch Control Circuit 2 High (tipm)
P1275 ‐ A/c Clutch Control Circuit 2 Overcurrent (tipm)
P128b ‐ Tcm Power Control Circuit 2 Low ‐ Tipm
P128c ‐ Tcm Power Control Circuit 2 High ‐ Tipm
P128d ‐ Tcm Power Control Circuit 2 Open ‐ Tipm
P128e ‐ Tcm Power Control Circuit 2 Overcurrent ‐ Tipm
P129c ‐ Inverter Control Circuit High (tipm)
P129e ‐ Inverter Control Circuit Overcurrent (tipm)
P1404 ‐ Egr Position Sensor Rationality Closed
P1501 ‐ Vehicle Speed Sensor 1/2 Correlation ‐ Drive Wheels
P1502 ‐ Vehicle Speed Sensor 1/2 Correlation ‐ Non Drive Wheels
P1572 ‐ Brake Pedal Stuck On
P1573 ‐ Brake Pedal Stuck Off
P1593 ‐ Speed Control Switch 1/2 Stuck
P1602 ‐ Pcm Not Programmed
P1607 ‐ Pcm Internal Shutdown Timer Rationality Too Slow
P1618 ‐ Sensor Reference Voltage 1 Circuit Erratic
P1628 ‐ Sensor Reference Voltage 2 Circuit Erratic
P1684 ‐ Battery Was Disconnected
P1696 ‐ Eeprom Memory Write Denied/invalid
P1697 ‐ Emr (sri) Mileage Not Stored
P1713 ‐ Restricted Manual Valve In T2 Range
P1745 ‐ Transmission Line Pressure Too High For Too Long
P1775 ‐ Solenoid Switch Valve Latched In Tcc Position
P1776 ‐ Solenoid Switch Valve Latched In Lr Position
P1790 ‐ Fault Immediately After Shift
P1794 ‐ Speed Sensor Ground Error
P1797 ‐ Manual Shift Overheat
P1897 ‐ Level 1 Rpm Bus Unlock
P2072 ‐ Electronic Throttle Control System ‐ Ice Blockage
P2096 ‐ Downstream Fuel Trim System 1 Lean
P2097 ‐ Downstream Fuel Trim System 1 Rich
P2098 ‐ Downstream Fuel Trim System 2 Lean
P2099 ‐ Downstream Fuel Trim System 2 Rich
P2100 ‐ Electronic Throttle Control Motor Circuit
P2101 ‐ Electronic Throttle Control Motor Performance
P2107 ‐ Electronic Throttle Control Module Processor
P2110 ‐ Electronic Throttle Control ‐ Forced Limited Rpm
P2111 ‐ Electronic Throttle Control ‐ Unable To Close
P2112 ‐ Electronic Throttle Control ‐ Unable To Open
P2115 ‐ Accelerator Pedal Position Sensor 1 Minimum Stop Performance
P2116 ‐ Accelerator Pedal Position Sensor 2 Minimum Stop Performance
P2118 ‐ Electronic Throttle Control Motor Current Performance
P2122 ‐ Accelerator Pedal Position Sensor 1 Circuit Low
P2123 ‐ Accelerator Pedal Position Sensor 1 Circuit High
P2127 ‐ Accelerator Pedal Position Sensor 2 Circuit Low
P2128 ‐ Accelerator Pedal Position Sensor 2 Circuit High
P2135 ‐ Throttle Position Sensor 1/2 Correlation
P2138 ‐ Accelerator Pedal Position Sensor 1/2 Correlation
P2161 ‐ Vehicle Speed Sensor 2 Erratic
P2166 ‐ Accelerator Pedal Position Sensor 1 Maximum Stop Performance
P2167 ‐ Accelerator Pedal Position Sensor 2 Maximum Stop Performance
P2172 ‐ High Airflow / Vacuum Leak Detected (instantaneous Accumulation)
P2173 ‐ High Airflow / Vacuum Leak Detected (slow Accumulation)
P2174 ‐ Low Airflow / Restriction Detected (instantaneous Accumulation)
P2175 ‐ Low Airflow / Restriction Detected (slow Accumulation)
P2181 ‐ Cooling System Performance
P2271 ‐ O2 Sensor 1/2 Signal Stuck Rich
P2273 ‐ O2 Sensor 2/2 Signal Stuck Rich
P2299 ‐ Brake Pedal Position / Accelerator Pedal Position Incompatible
P2302 ‐ Ignition Coil 1 Secondary Circuit‐ Insufficient Ionization
P2305 ‐ Ignition Coil 2 Secondary Circuit‐ Insufficient Ionization
P2308 ‐ Ignition Coil 3 Secondary Circuit‐ Insufficient Ionization
P2503 ‐ Charging System Output Low
P2504 ‐ Charging System Output High
P2610 ‐ Pcm Internal Shutdown Timer Rationality Too Fast
U0001 ‐ Can C Bus
U0001 ‐ Can C Bus
U0001 ‐ Can C Bus Circuit
U0002 ‐ Can C Bus Off Performance
U0010 ‐ Can Interior Bus
U0011 ‐ Can Interior Bus Off Performance
U0019 ‐ Can Interior Bus(+)/(‐) Circuit
U0020 ‐ Can Interior Bus Off Performance
U0100 ‐ Lost Communication With Ecm/pcm
U0101 ‐ Lost Communication With Tcm
U0114 ‐ Lost Communication With Final Drive Control Module
U0121 ‐ Lost Communication With Abs
U0121 ‐ Lost Communication With Anti‐lock Brake Module
U0121 ‐ Lost Communication With Anti‐lock Brake System (abs) Control Module
U0126 ‐ Lost Communication With Sas ‐ Can C (steering Angle Sensor)
U0141 ‐ Lost Communication With Fcm
U0141 ‐ Lost Communication With Front Control Module (tipm)
U0146 ‐ Lost Communication With Central Gateway
U0151 ‐ Lost Communication With Occupant Restraint Controller (orc)
U0154 ‐ Lost Communication With Occupant Classification Module
U0155 ‐ Lost Communication With Cluster/ccn
U0155 ‐ Lost Communication With Cluster/ccn (skreem)
U0161 ‐ Lost Communication With Compass Module
U0164 ‐ Lost Communication With Hvac Control Module
U0167 ‐ Lost Communication With Intrusion Transceiver Control Module
U0168 ‐ Lost Communication With Vehicle Security Control Module (skreem‐wcm)
U0168 ‐ Lost Communication With Vehicle Security Control Module (skreem/wcm)
U0170 ‐ Lost Communication W/up‐front Left Satellite Acceleration Sensor
U0171 ‐ Lost Communication W/up‐front Right Satellite Acceleration Sensor
U0172 ‐ Lost Communication W/left Side Satellite Acceleration Sensor 1
U0175 ‐ Communication W/right Side Satellite Acceleration Sensor 1
U0184 ‐ Lost Communication With Radio
U0186 ‐ Lost Communication With Audio Amplifier
U0193 ‐ Lost Communication With Traffic Information Receiver Module
U0195 ‐ Lost Communication With Sdars
U0197 ‐ Lost Communication With Hands Free Phone Module
U0197 ‐ Lost Communication With Hands Free Module
U0199 ‐ Lost Communication With Drivers Door Module
U0200 ‐ Lost Communication With Passenger Door Module
U0415 ‐ Implausible Data Received From Abs
U0447 ‐ Implausible Data Received From Central
U1008 ‐ Lin 1 Bus
U1008 ‐ Lin 1 Bus
U110a ‐ Lost Communication With Scm
U110c ‐ Lost Fuel Level Message
U110d ‐ Lost Communication With Security Siren
U110e ‐ Lost Ambient Temperature Message
U110f ‐ Lost Fuel Volume Message
U1110 ‐ Lost Vehicle Speed Message
U1113 ‐ Lost A/c Pressure Message
U1120 ‐ Lost Wheel Distance Message
U113b ‐ Lost Communication With Switch Bank Module
U1149 ‐ Lost Communication With Multifunction
U1159 ‐ Lost Communication With Asbs
U1169 ‐ Lost Communication With Intrusion Sensor 1
U1170 ‐ Lost Communication With Intrusion Sensor 2
U1179 ‐ Lost Communication With Intrusion Sensor 3
U1403 ‐ Implausible Fuel Level Signal Received
U1411 ‐ Implausible Fuel Volume Signal Received
U1412 ‐ Implausible Vehicle Speed Signal Received
U1414 ‐ Implausible/missing Ecu Network Configuration Data
U1415 ‐ Implausible/missing Vehicle Configuration Data
U1416 ‐ Implausible Security Siren Signal Received
U1417 ‐ Implausible Left Wheel Distance Signal Received
U1418 ‐ Implausible Right Wheel Distance Signal
U1419 ‐ Implausible Data Received From Ocs Sensor 3 ‐ Left Front
U141a ‐ Implausible Data Received From Ocs Sensor 2 ‐ Right Front
U141b ‐ Implausible Data Received From Ocs Sensor 4 ‐ Left Rear
U141c ‐ Implausible Data Received From Ocs Sensor 1 ‐ Right Rear
Gear / Tire Size Matrix
The info and chart below is from the following website: http://www.4lo.com/calc/geartable.htm
"Good "rule of thumb" calculation is to mutiply .12 by your tire diameter. (.12 X 38" = 4.56) (see more formulas at bottom of page)
The below table can be used to get a rough idea on gear ratios. The colors represent ideal RPM's at highway speeds (65). For highway cruising and best fuel economy stay towards the yellow (2600 rpm), around town daily driving is color coded green (2800 rpm), and for better towing power or just more 4-low power use the ratios near the red (3100 rpm). These calculations are assuming a manual transmission with a 1:1 ratio. If you drive an automatic your RPMs will be slightly higher, and the opposite is true if you have overdrive (your RPMs will be slightly lower)."
Hope this helps.
Discussion Starter · #8 ·
What is each part called in the front steering
Stolen from another website:
[How To] Install Remote Start in 08-09 Wrangler JK
This is my install write-up from my 2009 Sahara. I ordered the kit part# 82211437AC, which is a factory kit for 08-09, from a chrysler dealership on ebay. Since it was specified for the 08-09 model year, I assume earlier models are different. Below are a few pics to give you an idea. If you have any questions, I will answer the best that I can.
Before receiving the kit, I was talking with a tech at the dealership and he said that the jeep wont start until its programmed and that I may have to tow it in. Well, I wasn't thrilled with that and got thinking that there had to be another way. The way I described the installation below, will still allow you to drive the jeep to a dealership to do the programming. The guy that did the programming at the dealership updated the vin number on my jeep so its included in the system and warranty, From the link below, I printed the programming pages and took them with me to the dealership which helped because initially when he was trying to get it to program through the computer, it wasn't working. It would arm and disarm but wouldn't start. He came and told me about it, and I then told him about the pages on the seat that I brought. He went back, read through it and that's when he saw that the VIN had to be updated through chryslers system in order to work. Anyway, after all that, it worked great. You should be able to install this entire system in about an hour. Especially with my write-up.
I initially wasn't going to install the hood switch at all, basically because I just didn't want to and wasn't worried about someone being under the hood or anything else. Im the only one that will be working on my jeep and also I figured it was just a simple ground or open type of switch. But after receiving the kit and taking a closer look at it, there is a little resister inside the switch between the two pins. So even though the hood is closed and the switch is open, the circuit is still completed and it still sees a very small amount of ground. So the computer still checks for a completely/correctly installed harness. After coming back from the dealership, I also tested this by disconnecting the ground wire at the ground post from the switch, held the hood switch down and tried to start it and it wouldn't. So, youre going to need the hood switch. It only takes a few minutes to install it and is safer to have it anyway.
While I was installing the antenna module. I walked down the street to more than a 300' and was still able to start by remote. So the location I put it in works great.
Also, on a side note, the tech asked if I wanted any other changes with the computer, like the locking, unlocking etc. I already knew how to disable the seat belt chime, stop the horn from honking while arming, and only the driver door to unlock when disarming. So I brought up the doors locking thing at 20 mph. I dont like that and is just more wear and tear. Anyway, he was able to disable that feature as well, which is nice.
Instructions:
1. Disconnect ground cable on battery.
2. Install hood switch with supplied bolt, nutplate, and bracket.
3. Connect ground wire from hood switch to ground post that's about 8" away on driver side fender wall.
4. Route other end of wire along the wire harness that follows fender, then over to firewall, and down to the fuse/relay box and secure with enclosed tie wraps.
5. Pull up relay/fuse box by releasing the 4 tabs in the corners. Leave top cover on.
6. Disconnect center plug on the bottom.
7. Carefully pry bottom of plug cap off with small flatblade screwdriver on the sides. BE GENTLE.
8. Carefully pry out rubber wire seal.
9. Carefully pry up the top of the plug with a very small flatblade screwdriver. BE GENTLE.
10. Using a very small flat blade screwdriver or needlenose pliers, break little black plastic blocker in the 3rd hole of the bottom cap from the plug.
11. Feed new hood switch wire through the bottom cap, then rubber seal of the plug in the 3rd hole and then up through the plug. Make sure you have the terminal end of the wire facing the correct position before feeding into the plug. You will here it click into place once inserted. You can tell which way the terminal end faces by comparing it to the other wires already in the plug.
12. Reassemble plug and plug back into the relay/fuse box.
13. Reinstall fuse/relay box back onto the 4 post bracket. Watch other wires as you reinstall the box back onto the 4 post bracket.
14. Reconnect ground on battery and close the hood.
The jeep is still driveable with this wire installed in case youre unable to finish with the WCM and antenna installation at this point in time and need to continue another day. This wire does nothing at this point.
Installing new WCM and antenna.
1. Remove lower vertical cover under steering column by starting from the top and pulling the top ends, working your way down. Its held in by 4 clips I believe. After the 4 clips have been pulled, rotate the cover downward because its hinged at the bottom, and then remove it and set aside.
2. Lower the steering wheel as low as it will go.
3. Remove the steering column covers by removing the 3 torx screws from the bottom. One screw is easy to see, the other two are recessed up inside the cover. My torx driver wasn't long enough to reach up inside for the recessed screw on the right, so I put the torx driver in a vice and pulled the shaft out of the handle about a quarter of an inch and then it was long enough to reach it.
4. Split the covers and remove them. The rear part of the covers are just snapped together, pretty much like the rest of the jeep. LOL. Just pull part.
5. At this point, you can see the WCM by the key cylinder.
6. Carefully, with a very small flat blade screwdriver, remove the little yellow wire harness plug from the wiper arm assembly by depressing the little retaining clip and sliding toward you.
7. As youre facing the steering wheel, remove 1 phillips screw on the right side of the wiper arm assembly and then slide the wiper arm assy toward the center of the jeep and set aside.
8. Now you can see the 1 screw that holds the WCM in place. Remove it and then push away the arms on the WCM to "unclip" it from the column but DONT disconnect the plug. Just let it hang.
9. Install the new WCM and the 1 retaining screw.
10. Install the wiper arm assembly in reverse order from above.
11. Plug in the wire from antenna module into the new WCM and route excess wire under steering column.
12. Hold antenna module in place against steel plate as seen in pic, mark 2 holes, drill and attach module.
In order to start the jeep, you will need to hold the old WCM close to the key, then start the jeep. After it has started, continue holding the WCM close to the key while the jeep is running for about 3 seconds and then let go of it and let it hang. You wont have any problems with it after that. Drive to a dealership and have them cut the new keys first, then unplug the plug from the old WCM and plug it into the new WCM, and then follow the directions for programming the new keys and WCM. After that's done, drive home.
13. Reattach steering column covers in reverse order from above
14. Reinstall lower vertical cover under steering column in reverse order from above.
DONE !!
http://site.justforjeeps.com/guide/82211437AC.pdf
Image uploading. Refresh page to view
What was I thinking?
2008 JKU
Popular Threads​
About Fire Extingushers!
Media and Navigation
Mygig Anyone
Mygig Database Thread
OEM Stereo Wiring Diagram
How to Upgrade your sound system while retaining factory head unit (Infinity)
OEM Radio Removal
2011 Dash removal, lockpick-camera install
2012 Dash removal, lockpick-camera install (with pictures)
Write-up Video monitor install stock dvd player
General Maintenance and Trouble-Shooting
JK_3.6 oil filter change
Here is some info related to diagnosing axle noise
Programing a third key
Daystar JK hood-wranglers install
JK 3.8 Oil filter list
Tools to keep close
Differential fluid service 1
Differential fluid service 2
How to perform a 6000 mile service
Brake Pad Replacement Using Hawk Brake Pads
OEM Rubicon Locker Study:
OEM Fuel Pump Module Study:
OEM PCV Valve Study:
OEM TIPM Study:
OEM e-disco Smartbar study:
OEM Parking brake study:
OEM Ball Joint Study:
OEM Front Wheel Unit Bearing Study:
Write-up rear door panel removal
JK grill removal
Front end alignment and diagram
Clunk fixed-Steering Knock
Steering knock, another cause!
Parking Brake Is Self Adjusting
Tru-Lok Inner Workings
Driveshaft Boot Clamp ripped off!
No 4-low ...fixed!
Misfiring 2010 JKU 3.8
Mopar Speed Control Install / troubleshoot
How To get your keys and/or other stuff that you lost inside the dash!
JK Facts and Specs
Weight of a Stock JK Rubicon Unlimited
Differences between 07-10 rubicons?
JK model year differences?
Is it a 07,08,09, or 2010 Wrangler?
Difference between 2008 and 2007 JK's
Lighting and Electrical
Rigid Dually and Dually D2 Light Patterns
Custom homebuilt aux. lights under $200
Dash LED Color Change
Selectable Battery/Accessory Power Source
Easy Switched Power Source
Headlight Shootout
Rallylight/Hella headlight upgrade install
LED Auxiliary Lighting
Daytime Running Lights
Lets see your lights!
Home built power distribution panel and Air horn
Aux. Back-up Lights on Factory bumper
Great Idea for Backup Lights
Recessed rear bumper light install
Custom Build: JK Electrical Panel
Daniel Stern Lighting for my JK
Installing Mopar 7-pin trailer adapter and brake controller on the JK
Walmart tools don't Work! (basic trailer wiring install)
Footwell glow lights (l.e.d.)
CB Radios and Antennas
CB Options
Mount options 1
Mount options 2
Antenna options 1
Antenna options 2
Suspension and Steering
Max flex vs. useful flex (Currie Anti-Rock)
Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles
Another Possible Cause Of Death Wobble and Steering Problems
How to change (and upgrade) your Drag Link End
Rubicon Take off Suspension vs Teraflex Leveling kit
Rubicon JKU spring info / link to teraflex 2.5" bb writeup
Rock Krawler 3.5" Mid-Arm Flex and RRD Shocks Installed!
Thing's to check after you lift (cutting the pinch seam)
Cutting the pinch seam with a Dremel
Armor and Skid Plates
Installed some ACE Rock Sliders
ARB front bumper install/mini write up
Evap skid plate
Trans/oil pan skid plate
JK Top Options
Bestop Trektop
Bestop Supertop problems
Power and Performance
OEM Mechanical Fan Retrofit
Superchips installed today-review
Superchips Error
Ripp gen II stage II supercharger
Gears, Wheels and Tires
DEFINITIVE WHAT SIZE TIRE/Wheel/SPACER/BACKSPACE THREAD
Want to know your gear ratio for sure?
Gear/tire for Auto VS Standard
Power Loss from 35s-Ideal gear setup/ tire size
Chop Chop, stock bumper mod, spare tire clearance
Gear Calculator
Deflation and Inflation tool
Spidertrax Wheel Spacer Install
Definitive list of 15" wheels that will fit JK
Jim's Jeep; JK rear axle build with Super 44s, ARB, and 4.88 gears.
Other Usefull Ideas
Inexpensive mod list
I made a DIY video for fender cutting
Show us how you trimmed your flairs!
Easy Modification But Effective, drill the mirrors
Mesh Grill Mod
Mopar Fuel Filler door install
OX locker installed
JK exhaust Magnaflow D.I.Y. less than $100
transmission cooler-shrockworks-midwidth bumper install
wasted $ what mods are not worth it
Pinch seam cut-off
JK Custome cowl snorkel
I want a snorkel
Axle vent relocation
Homemade lightbar/rack writeup part 1 (picture happy)
Home made trunk cover for JK?
Woods Viair OBA Install
Rear Floormat Securement for door-less driving
Video Installs and How-to's
JK Build Threads
(planman)Info for going to 35" tires on a JK
(planman)Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares
(planman) 40s on a 3" OME LT lift, 1" BL, & flat flares
CRWL:TH!S-JK Buggy by Carolina Truggies(KRIPPLE)
30 day Unlimited Rubicon build...(BRICKTOP2)
blackanwhiteriot JK build thread
rballman JK build - da hoopty
MudHound Build Thread
Mattman8706 build thread
WVUJeeper's Build Thread
Total build with pics!(MilitaryJK4455)
Blood, sweat and beers... a.k.a. voodooJK build.
My 2010 Rubicon(MoparToYou)
Steve's 2009 2 Door JK Build(1398653)
08 Silver Unlimited BUILD W/ unexpected law suit(jamie_s_72)
KBeran's JK Build
blood,sweat and TEXAS beer... tube fenders(jeepbronco1)
b_c's build thread
Jim's Jeep; THE OBSESSION LIVES ON! (JLC08JK)
Deerassassin22's build thread
molshove's build thread
aznjeep's build thread
Dronac's build thread
11RUBICON's build thread
Jeep 7 - Ultimate Off Roader
Surviving the Frozen Northern Yankee Wasteland: ArticRubi's Build Thread
Avenger Supercharger Half Top Install (dvdsjk's build thread)
Ok, Its Official, I'm Back Sahara Tan Sahara Build (Another one from dvdsjk)
SickBoy357 JK build
Coping with the Urban Coyote - Jezzalachis' JKU Build Thread
1 - 10 of 10 Posts
Status
