Is there anywhere I can run my spare XJ til it falls apart? I bought it for parts and am done with it, if it wasn't for the $600 in back DMV fee's plus failing of smog I might keep it.
Hammerspace = San Jose, CA.Hi everyone, I've been working on my Jeeps fixing them up by myself and I can tell you it gets tiring quick when you always work alone... so I'm here looking for someone that might like to get together and work on their Jeep's since I work at a large shop where I hang out often wrenching, maybe go off roading? I have 5 Jeeps now so I know a thing or two about them but like anyone else I still need help figuring things out time and again. Right now I'm having issues with my 88' XJ, it passed smog runs good and strong off road but once you get over 55 mph there is no power accelerating, anyone local can help out? Did I mention I have a full shop with tools to work on Jeeps?![]()
I think I may be free that weekend. If I can get my tire carrier mounted by then I'd be down if you can find a couple peopleI plan on going to Hollister Hills Oct Sat 26 to Sun 27 anyone up for some fun? Also I have a spare jeep I want to have fun with, do they have to be registered to be used at the park?
Dumb question - replace the thermostat or boil off coolant lately?I'm checking out all this RENIX stuff hmmm and so far so good but that has me wondering what is up with my Jeep? Lately its been boiling over on these warm days?
Hollister SVRA isn't that out of your way and has plenty to choose form as far as easy to extreme trails goes.I live in Merced, are there any places to go off road, I own a '13 wrangler sport... I want to se what this thing can do. It's not a rubicon, so nothing real heavy duty... Thanks in advanced.
I'm setting up a run to Frank Raines sat 11/2 if you wanna meet out there. You're welcome to come out.Greg_2013 said:I live in Merced, are there any places to go off road, I own a '13 wrangler sport... I want to se what this thing can do. It's not a rubicon, so nothing real heavy duty... Thanks in advanced.
I changed the thermostat (160) out again for the 4th time and replaced the reservoir and cap, replaced the water pump and bleed the system, its not boiling over so much but still running around 210.Dumb question - replace the thermostat or boil off coolant lately?
RENIX uses the "closed" cooling system. Nothing wrong with it (if there were, would OEMs be going to it?) but it does take a bit of care to return to service.
Search up my posts on drilling the thermostat flange, it will tell you how to make the system self-purging. If the system is partially or wholly drained (through regular service, through boilover, or anything like that...) you'll end up with an air pocket behind the thermostat. This will cause the thermostat to not sense the temperature of the coolant, and to not open, which will cause a boilover. Every time.
(It will even make it happen when it's snowing - it just takes longer to happen.)
210*F is the "Spec Operating Temperature" for the 6-242 engine, and it's common for most engines these days.I changed the thermostat (160) out again for the 4th time and replaced the reservoir and cap, replaced the water pump and bleed the system, its not boiling over so much but still running around 210.
However new problem... I was on my way to hollister hills and when towing my jeep on a dolly for the first time with both trans and transfer in neutral (was told okay to do) i blew the casing out... I disconnected the drive line and brought it home as you can see its a goner.
Thank you I will see if I am free.johnridesjeeps said:I'm setting up a run to Frank Raines sat 11/2 if you wanna meet out there. You're welcome to come out.
